take the fat hose off the top off and the small line to the fire wall off. the small line its best to cut the old rubber end then remove it as the tree likes to break. then use a new 1 inch of vac line to put it back on later.
you need to un hook the evap back theres still, and the map if its not done yet.
the harness there will lift up some more after its all unhooked, then lift and slide the blower out from under it.
you need to take the tb cables off too.
dont forget the egr tube on the driver side of the lim, is one bolt.
