First I could see being valve cover or lower intake gaskets. The second, we can see seepage coming in from out of the view. This could be the LIM gasket, could be the turn around on the end of the LIM, and it could be a trans casing seepage.
Trans seepage is not very likely in this area, although a little fluid may have flung up and found the breather hole of the trans. I'm doubtful that it's trans. And if you are paranoid and go check your trans fluid..I bet it's not 100% filled..but that's normal.
