Thread: seat belt light stays on after its hooked together
Results 1 to 20 of 28
  1. #1 seat belt light stays on after its hooked together
    May 2012
    Cedar Rapids, Iowa
    What would cause this?
  2. #2 Re: seat belt light stays on after its hooked together
    the wire from the seat belt broke, or came unplugged. follow the clip part by the console down and under the seat, you'll see a black wire coming off the part that gets bolted to the floor.
  3. #3 Re: seat belt light stays on after its hooked together
    Or cover the bulb
    04 Comp G.
  4. #4 Re: seat belt light stays on after its hooked together
    May 2012
    Cedar Rapids, Iowa
    Wow fast replies. Thanks Scotty and red. Could it be the buckle itself if the wires aren't the problem?
  5. #5 Re: seat belt light stays on after its hooked together
    SWPA
    Same thing happened to me. I just unplugged the damn connector.
  6. #6 Re: seat belt light stays on after its hooked together
    inside the buckel can go bad, but likely the wire got damaged. its a easy check.
  7. #7 Re: seat belt light stays on after its hooked together
    May 2012
    Cedar Rapids, Iowa
    Okay just checking all my bases. Thanks guys
  8. #8 seat belt light stays on after its hooked together
    When in doubt cover the dummy bulb lol
    04 Comp G.
  9. #9 Re: seat belt light stays on after its hooked together
    May 2012
    Cedar Rapids, Iowa
    Lol I dont think my wife would like that too much. Its her car
  10. #10 seat belt light stays on after its hooked together
    What she doesn't know doesn't hurt her lol
    04 Comp G.
  11. #11 Re: seat belt light stays on after its hooked together
    It's just a light anyways if you can't find a tear on the wiring then bam next easy/cheapest fix and seatbelts will still work like they should
    04 Comp G.
  12. #12 Re: seat belt light stays on after its hooked together
    SWPA
    On my car it was more than a light. The dinger went off too.
  13. #13 Re: seat belt light stays on after its hooked together
    Me no have working chimes so covering the light did it for me
    04 Comp G.
  14. #14 Re: seat belt light stays on after its hooked together
    May 2012
    Cedar Rapids, Iowa
    I haven't even paid attention if that went off. Like when you open the door? What dinger?
  15. #15 Re: seat belt light stays on after its hooked together
    SWPA
    Series of dings every few minutes to annoy the sh!t out of you.
  16. #16 Re: seat belt light stays on after its hooked together
    May 2012
    Cedar Rapids, Iowa
    Mine have never done that as far as I know. Does that mean its more than the seat buckle? Also would I have to warn the next seller if I was to sell the car?
  17. #17 Re: seat belt light stays on after its hooked together
    I have this problem in the Silverado it's annoying. Exact reason I did away with the chimes in the GP.
    04 Comp G.
  18. #18 Re: seat belt light stays on after its hooked together
    May 2012
    Cedar Rapids, Iowa
    Just an update I checked the wiring and it looked good. I blew into the seat buckle and the light goes off now. Idk maybe it was just dusty.
    Bad news I checked my coolant and it was sludged up . Looks like its lim time
  19. #19 Re: seat belt light stays on after its hooked together
    thats dex coolant sludge. you need to flush your coolant.
    dusty buckle, i believe it lol
  20. #20 Re: seat belt light stays on after its hooked together
    May 2012
    Cedar Rapids, Iowa
    Can I do that with out running water as I live in an apartment and have no way to get any
  1. Seat belt light on AFTER car is off
    By gtpterp in forum General Tech Discussion
    Last Post: 05-08-2013, 02:51 PM
  2. Seat belt light stays on?
    By Prixboy95 in forum Audio, Security & Visual Electronics
    Last Post: 04-30-2013, 08:38 PM
  3. Seat belt warning Light stays on..all day.
    By brenglen in forum General Grand Prix Discussion
    Last Post: 06-26-2012, 05:51 AM
  4. Now what? Seat belt light and chime...
    By stealthee in forum 04+ Specifics
    Last Post: 11-27-2011, 12:18 AM
