Thread: Do you have to remove the Alt. when doing 1.9 rocker arm install?
Results 1 to 15 of 15
97AutoXVette Do you have to remove the... 06-04-2014, 06:23 PM
Russosaur Re: Do you have to remove the... 06-04-2014, 06:24 PM
97AutoXVette Re: Do you have to remove the... 06-04-2014, 06:37 PM
Russosaur Re: Do you have to remove the... 06-04-2014, 06:38 PM
97AutoXVette Re: Do you have to remove the... 06-04-2014, 06:42 PM
wa04compg Re: Do you have to remove the... 06-04-2014, 06:39 PM
Russosaur Re: Do you have to remove the... 06-04-2014, 06:47 PM
97AutoXVette Re: Do you have to remove the... 06-04-2014, 06:51 PM
Fivefingerdeathpunch Re: Do you have to remove the... 06-04-2014, 06:53 PM
wa04compg Re: Do you have to remove the... 06-04-2014, 06:56 PM
97AutoXVette Re: Do you have to remove the... 06-04-2014, 06:59 PM
Russosaur Re: Do you have to remove the... 06-04-2014, 07:05 PM
97AutoXVette Re: Do you have to remove the... 06-04-2014, 09:12 PM
BillBoost37 Re: Do you have to remove the... 06-05-2014, 05:47 AM
97AutoXVette Re: Do you have to remove the... 06-22-2014, 07:32 AM
  1. #1 Do you have to remove the Alt. when doing 1.9 rocker arm install?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Let me know what worked best for those of you who installed aftermarket rockers. Not sure how intensive the swap is.
    Thanks!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Yes you do because you gotta remove the VC plus I think the bracket is in the way of a rocker.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by russosaur View Post
    yes you do because you gotta remove the vc plus i think the bracket is in the way of a rocker.
    Sent from the milky way
    nooooooooo!!!!!
    2002 GTP sedan:
  4. #4 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Apr 2012
    Dayton, OH
    What are you afraid of coolant?
    2012 F150 STX
  5. #5 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Mar 2014
    Cincinnati, OH
    Naa... Just was hoping for a simple install. Guess the coil and alt. aren't too bad to remove.
    2002 GTP sedan:
  6. #6 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Oct 2011
    Puyallup WA
    Alternator and coil bracket need removal
    08 G8 GT - exhaust Tune
  7. #7 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Apr 2012
    Dayton, OH
    You not doing springs? Those would be more of a challenge than removing the alt and tensioner brackets.
    2012 F150 STX
  8. #8 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Mar 2014
    Cincinnati, OH
    I am going to keep the stock springs for now. Just going to keep shift points under 5500 rpm and see how it does. (unless you'd suggest otherwise??)
    2002 GTP sedan:
  9. #9 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Just don't mix up the alternator bolts when you re-install it. Seem too many times that people put the long bolt in the top hole and it goes through the valve cover,
  10. #10 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Oct 2011
    Puyallup WA
    I ran 1.9's on stock springs shifting at 5850
  11. #11 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Mar 2014
    Cincinnati, OH
    Thanks for the tip!
    Quote Originally Posted by wa04compg View Post
    Good to know. I should be fine shifting at 5500 then (Knock on wood)
    2002 GTP sedan:
  12. #12 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Apr 2012
    Dayton, OH
    Funny I don't see how you mess up those bolts. I usually lay the bolts in the part they come off of or remember where they go plus the one bolt has a stud on the top of it iirc.
    2012 F150 STX
  13. #13 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Mar 2014
    Cincinnati, OH
    Also, I just torque all the new rockers down to the same torque, whether the valve for that particular rocker is open or closed right? Seems like for these roller journal style rockers (ZZP/stock style) they can be torqued down whether said valve is open or closed...
    2002 GTP sedan:
  14. #14 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    #1 if a few more bolts makes this "intensive" you may want to skip doing rockers.
    #2 Please do your homework and find out that if you have new reusable bolts, torque should be 25ft lbs with the valve closed and no pressure on it
    #3 Sure most of us have torqued them when the valve is open.. but then turn the motor some..retorque, turn more..retorque.
  15. #15 Re: Do you have to remove the Alt. when doing 1.9 rocker arm install?
    Mar 2014
    Cincinnati, OH
    Another question on this topic:
    Is it wise to replace the coolant elbows when removing the tensioner bracket? It looks like they will inherently have to come out and coolant drained since they are connected to the tensioner bracket, right??
    2002 GTP sedan:
  1. Misfire help after rocker install
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2012, 12:58 AM
  2. Rocker install?
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2012, 12:34 PM
  3. how 2 remove the rocker molding on a 02 GT
    By 13781verona in forum General Tech Discussion
    Last Post: 12-02-2011, 10:26 PM
  4. er rocker install
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2011, 01:49 PM
  5. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
