Thread: er rocker install
Results 1 to 20 of 23
  1. #1 er rocker install
    May 2008
    Winnipeg, MB
    I have the er rockers
    what tools?
    what other parts?
    I don't plan on increasing the shift points so don't think I need new springs.
    2007 Pontiac Grand Prix
  2. #2 Re: er rocker install
    Installing rockers without retuning and increasing shift points is kinda like Top Swapping without headers....
  3. #3 Re: er rocker install
    May 2008
    Winnipeg, MB
    sorry for my noobish questions
    I thought the er rockers were the best option if I didn't want to get into replacing everything under the valve covers.
  4. #4 Re: er rocker install
    Sure...you can run them without upgrading springs, but I was getting at is that you won't see max gains without running up the RPM's.
    Spend the extra money and do it right the first time?
    Plus...a tune makes a world of difference...and Will @ Overkill is in Canada...
  5. #5 Re: er rocker install
    May 2008
    Winnipeg, MB
    are the stock shift points lower then what the stock springs can handle? so with a tune where the shift points are increased with stock springs I will be fine?
  6. #6 Re: er rocker install
    You can shift up to 6K on stock springs...anything really past that and your risking valve float...which is no bueno.
  7. #7 Re: er rocker install
    May 2008
    Winnipeg, MB
    alright then, back to my original question, what else do I need to do this mod?
  8. #8 Re: er rocker install
    I'd honestly get some Crow 105 springs, matching retainers, Comp Cams Re-useable rocker bolts, new valve cover gaskets/grommets...and have Will tune it after your done.
    Tune + Rockers/Springs = 20 FWHP? Maybe?
  9. #9 Re: er rocker install
    May 2008
    Winnipeg, MB
    If I use the stock springs how much gain could I see? From what I understand replacing the springs is tricky so is it even worth the effort.
  10. #10 Re: er rocker install
    Replacing springs is only difficult if your name is Rynoman03
    LOL,
    But seriously...its easy if you have an air compressor and the right tools.
    If not, then installing ER Rockers and getting a solid, dialed in tune...shifting at 6K...you'll not only notice a performance difference but I'm sure you'll see better MPG's as well.
  11. #11 Re: er rocker install
    May 2008
    Winnipeg, MB
    It took me five months to build up the courage to do a HV3 install, did it properly and now I'm hoping I can do the rockers next. Let me know if there is anything difficult about it that would screw up the car if not done exactly right.
  12. #12 Re: er rocker install
    No...
    Just make sure you torque everything correctly and clean out the bolt holes before re-install...I think Comp Bolts are 25 ft.lbs?
  13. #13 Re: er rocker install
    May 2008
    Winnipeg, MB
    the stock rocker bolts can't be reused?
  14. #14 Re: er rocker install
    Quote Originally Posted by tod1d View Post
    No, they are Torque To Yield (TTY).
  15. #15 Re: er rocker install
    Dec 2008
    Lawndale, CA
    I used this as a reference when I did mine. I kept the stock springs and got the reusable bolts. But I don't drive mine ahrd enough to be shifting above 6K rpm's.
    ClubGP:
  16. #16 Re: er rocker install
    May 2008
    Winnipeg, MB
    my rockers came packaged in newspaper, no labels marking 1.8 from 1.85 hmmmm
  17. #17 Re: er rocker install
    May 2008
    Winnipeg, MB
    Quote Originally Posted by The Guz View Post
    ClubGP:
    thank you
  18. #18 Re: er rocker install
    Used I suppose?
  19. #19 Re: er rocker install
    May 2008
    Winnipeg, MB
    just slightly, anyway of telling them apart?
  20. #20 Re: er rocker install
    L76 springs.
    They're cheaper, and not as damaging to the tensioner.
    Will is also just a few miles away from him.... About 2000 to be precise.
  1. Rocker install?
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2012, 12:34 PM
  2. 1.9 Modified Rocker Install
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2011, 06:59 PM
  3. any Tech Tip for rocker install?
    By Mitchstrp in forum General Tech Discussion
    Last Post: 01-04-2011, 09:56 PM
  4. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
