Thread: I think I'm in big trouble, knocking sound from engine....
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: I think I'm in big trouble, knocking sound from engine....
    GT Level Member thegipper's Avatar
    grafton, wi
    169k miles. What really sucks is I took VERY good care of it and is otherwise in perfect condition (minus a few dings you know).
    Literally everything works on it, tranny shifts perfectly and so on.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  2. #22 Re: I think I'm in big trouble, knocking sound from engine....
    It happens dude. Don't stress over it, find a good JY motor and swap it in.
    04 Comp G.
  3. #23 Re: I think I'm in big trouble, knocking sound from engine....
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    Damn have 264k gen v on a 3.3 and cant seem to pop a piston trying hard to have a reason to install new motor
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  4. #24 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    This would be the second 3800 that took a dump on me, first was my bonneville which made it to 180k miles.
    I'll probably sell the car and get the wife a new SUV. I'll drive her TL instead.
    I'm over these 3800's.....
  5. #25 Re: I think I'm in big trouble, knocking sound from engine....
    Apr 2009
    Elkhart
    Damn that sucks
  6. #26 Re: I think I'm in big trouble, knocking sound from engine....
    If it makes you feel any better I'm on my 3rd gp the most recent is on its 3rd engine.
  7. #27 Re: I think I'm in big trouble, knocking sound from engine....
    Apr 2009
    Elkhart
    Lol im on my 3rd transmission 1st one was forward band second was first gear burnt and now the 3rd is the stock one i rebuilt
  8. #28 Re: I think I'm in big trouble, knocking sound from engine....
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    CHECK YOUR BALANCER! Just like the previous posts, take off your belts reach in and see if the balancer moves. If it does that means the rubber is shot and you will have to replace it. My GTP sounded the same and well it was the balancer
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  9. #29 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    Quote Originally Posted by 97gtpjoe View Post
    I'll do that but I found metal "sparkles" on the dip stick. Pretty sure I spun a bearing.
  10. #30 Re: I think I'm in big trouble, knocking sound from engine....
    Jan 2009
    Check balancer first, easier fix
    Sent from my LG-D959 using Tapatalk
  11. #31 Re: I think I'm in big trouble, knocking sound from engine....
    Lol, what good would fixing a broken balancer do if the bottom end is shot?
  12. #32 Re: I think I'm in big trouble, knocking sound from engine....
    a broken balancer can sound like a blown rod bearing is what they are saying, its free to look at it right?
  13. #33 Re: I think I'm in big trouble, knocking sound from engine....
    Yeah but sparklies in the oil = engine is done anyway.
  14. #34 Re: I think I'm in big trouble, knocking sound from engine....
    unless he was just seeing the sun shining on the stick? lol
    i always try to root for a not blown motor.
  15. #35 Re: I think I'm in big trouble, knocking sound from engine....
    I was at first too, Tyler and I both said to check the oil, and I agree with Tyler he should drain the pan, 5 quarts of oil and a filter is like $20 at walmart.
  16. #36 Re: I think I'm in big trouble, knocking sound from engine....
    Wanna know the easy way to tell if it's a motor?
    It sounded like it might be and then stopped starting nice. Balancer shouldn't cause that, flex shouldn't cause that.
    90% sure from the vid, it's a motor. Definately though.. give it a quick rev ...the noise a lower end makes on decel is unmistakable
  17. #37 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    Just checked another video I had made, its makes a lower pitched "knock" on decel but it makes a higher pitched "knock" on accel. Pretty sure its toast, especially with finding some sparkles in the oil.
    I will obviously check the balancer just for ****s and grins.
    Thanks for the help guys
  18. #38 Re: I think I'm in big trouble, knocking sound from engine....
    So ill ask again drained the oil yet? Or you could make a whole bunch more videos and keel reving it until it punches a hole out the skirt of the block when it locks up.
  19. #39 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    I haven't started since day one Vet........it was an old video.
    And no, I haven't drained the oil. I've been too busy but I'll be sure to do that.
  20. #40 Re: I think I'm in big trouble, knocking sound from engine....
    So any update on this?
  1. Knocking Sound from Engine bay.
    By BoostenGTP in forum General Grand Prix Discussion
    Last Post: 06-14-2012, 11:42 PM
  2. Knocking sound..
    By Jordin in forum Brakes/Suspension/Chassis
    Last Post: 02-29-2012, 09:52 PM
  3. Engine knocking/odd sound
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 08:12 PM
  4. knocking sound from engine
    By BSP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 09:03 AM
  5. Ticking/knocking sound in engine compartment
    By 200GpGt in forum General Tech Discussion
    Last Post: 04-17-2010, 03:54 PM
