Thread: I think I'm in big trouble, knocking sound from engine....
Results 1 to 20 of 40
  1. #1 I think I'm in big trouble, knocking sound from engine....
    GT Level Member thegipper's Avatar
    grafton, wi
    Driving home today and just before I got home I had to pass someone and when doing so I heard a knocking noise come from the engine.
    Got home popped the hood and heard this knocking noise coming from the engine, seems louder on the passenger side near the pulleys.
    http://s1127.photobucket.com/user/th...ofmi3.mp4.html
    http://s1127.photobucket.com/user/th...sxyik.mp4.html
    Hooked up my phone with Torque to check for KR, not sure if that means anything but i have 0 KR like usual.
    Let it sit for awhile, started it back up and if anything its louder. Sounds like "rod knock" or something serious.
    So......am I fuuKed?
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  2. #2 Re: I think I'm in big trouble, knocking sound from engine....
    That bottom end is history likely rod bearing(s).
  3. #3 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    That's what I'm thinking. I've heard that same exact noise from 2 different 3800's and both ended poorly.
  4. #4 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    And I'm assuming if it is rod bearings its new motor time. Not worth it to try to replace correct?
  5. #5 Re: I think I'm in big trouble, knocking sound from engine....
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Sounds like you get to play the motor swap game, at least you can go SC now.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: I think I'm in big trouble, knocking sound from engine....
    This is rod knock.
  7. #7 Re: I think I'm in big trouble, knocking sound from engine....
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    just for sh*t and grins look at the balancer and see if the rubber has ripped had that problem on my gtp and I thought the motor let go
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  8. #8 Re: I think I'm in big trouble, knocking sound from engine....
    Apr 2012
    Dayton, OH
    Possible flexplate? Just because its not super constant like the video slick posted
    2012 F150 STX
  9. #9 Re: I think I'm in big trouble, knocking sound from engine....
    Quote Originally Posted by 00grandprixgtp View Post
    This, you don't really hear it till you rev the engine.
  10. #10 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    Not exactly sure what I'm looking for, can you elaborate?
  11. #11 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    And if it was the flex plate how could I tell that it was bad?
  12. #12 Re: I think I'm in big trouble, knocking sound from engine....
    Look at the harmonic balancer, if the rubber is ripped/torn it will make a noise like someone sticking a wooden spoon in a box fan.
    Jack up car remove dust cover and visually inspect the flexplate from under the car.
  13. #13 Re: I think I'm in big trouble, knocking sound from engine....
    jayroca tried the flex plate game too and ended up buying a 2nd gtp i realize its not the same vehicle but id be damn suprised if its anything besides the bottome end.
    Tell you the same thing i did him instead of start it and rev it 30 times to try figure out what it is do the easy things pull the plugs check them drop the oil and see if its glittery, then pull the cover by the flex and see if its cracked or broke the bolts off.
    Sorry man my moneys on engine went bye bye.
  14. #14 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    I'll have to check it tomorrow, no time left today. Thanks for the help so far today, I have another video I'll post in a bit here.
  15. #15 Re: I think I'm in big trouble, knocking sound from engine....
    Starting and reving it isnt going to do anything besides possibly make it worse.
  16. #16 Re: I think I'm in big trouble, knocking sound from engine....
    Apr 2009
    Elkhart
    when my hb went I was in boost and it sounded like a rod let go even took the belts off and still rattled but mine seemed to go away when u got into full boost because it would lock into place I though forsure when I heard it the motor was done looked in the wheel and found balancer.jpg
  17. #17 Re: I think I'm in big trouble, knocking sound from engine....
    That happened to my 97, though I blew up my engine.
  18. #18 Re: I think I'm in big trouble, knocking sound from engine....
    its time to give one up for the gipper it seems.
    get him a new power plant. if you drive or run it longer it will sound like slicks vid.
    check all the other things listed too. all relevant.
    but it does sound like a rod bearing to me too.
  19. #19 Re: I think I'm in big trouble, knocking sound from engine....
    grafton, wi
    Ok not starting it anymore, although I think I have confirmed my fears. I checked the dipstick and found some sparkles in it. Not a ton, but enough to notice.
  20. #20 Re: I think I'm in big trouble, knocking sound from engine....
    Apr 2009
    Elkhart
    bummer how many miles where on it?
  1. Knocking Sound from Engine bay.
    By BoostenGTP in forum General Grand Prix Discussion
    Last Post: 06-14-2012, 11:42 PM
  2. Knocking sound..
    By Jordin in forum Brakes/Suspension/Chassis
    Last Post: 02-29-2012, 09:52 PM
  3. Engine knocking/odd sound
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 08:12 PM
  4. knocking sound from engine
    By BSP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 09:03 AM
  5. Ticking/knocking sound in engine compartment
    By 200GpGt in forum General Tech Discussion
    Last Post: 04-17-2010, 03:54 PM
