Thread: vacuum leak?
Results 1 to 4 of 4
  1. #1 vacuum leak?
    Jul 2013
    adrian, mi
    I have seen on a couple of threads (cant seem to find them now) that your vacuum at idle should be around -20 -21. Is this correct? Im running 1.9rockers, headers, 3.4 pulley, zzp tune, al103's, 180tstat and fwi and only seeing around -10 at idle. 98gtp. Im still getting kr but its not consistant. one day it will be under .5* next day it will be around 3*. When im scanning im doing this at op temp. Just trying to figure out if theres a leak causing me to run lean. thanks in advance
  2. #2 Re: vacuum leak?
    -10 is likely pounds, whereas -20 is Hg's.
  3. #3 Re: vacuum leak?
    Jul 2013
    adrian, mi
    Ok I will see what it's reading it in thanks edit: it's in lbs
  4. #4 Re: vacuum leak?
    SE Level Member charlieRobinson's Avatar
    May 2014
    OH
    Hollas did you get your lean condition resolved?
    I have one right now. Seeing 16+ LTFT super lean at idle. I have an xp cam and I see about -7.5PSI vacuum at idle. When i convert this to in/Hg i get about -15.
    What should my vacuum be at idle with an XP cam?
    Thank you
    1999 Buick Riviera - L67
    PLX wideband +HPT pro +X-P HOT cam, 140#springs, 2x chain, LS7 lifted
    ZZP SS Headers + 3" Downpipe + 200 Cell Cat.+ Aero Resonator
    Gen V swapped L67, 60# injectors, E85, N*&LQ4MAF
  1. Vacuum Leak?
    By Oilcan in forum Engine
    Last Post: 11-03-2013, 09:00 PM
  2. Vacuum Leak?
    By crock in forum General Tech Discussion
    Last Post: 08-21-2011, 12:09 AM
  3. Vacuum Leak Help
    By RichardL12 in forum General Tech Discussion
    Last Post: 06-03-2010, 06:28 AM
  4. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  5. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
