Thread: 2000 gtp died
Results 1 to 9 of 9
  1. #1 2000 gtp died
    Jun 2010
    Bakersfield, CA
    Driving home today my gtp died about a block from home. Was able to coast to my house. Right before it died it lost power, the traction control light came on and it shuttered pretty bad. Then check gauges came on. After i parked it, i was able to start it and it sounded normal. The low coolant has been coming on periodically, but it has coolant and no leaks. Also the traction control has flashed a couple times. There was no overheating and nothing else out of the ordinary. Any guesses? Going to plug the scanner in later to see if there seed any codes.
    Sent from my DROID RAZR using Tapatalk 2
  2. #2 Re: 2000 gtp died
    Codes will help.
  3. #3 Re: 2000 gtp died
    Jun 2010
    Bakersfield, CA
    Hooked the scanner to it... No codes stored!. Starts and runs fine. No check gauges or check engine light. Scan gauge shows 14.1 volts. I'm stumped... And afraid to drive it anywhere!
  4. #4 Re: 2000 gtp died
    St. Louis
    Did you happen to notice if the tach dropped to zero before it died? I'm thinking crank position sensor if all else checks out.
  5. #5 Re: 2000 gtp died
    Jun 2010
    Bakersfield, CA
    I'm not sure... I was in panick mode, thinking wtf is going on.
  6. #6 Re: 2000 gtp died
    I'd swap the crank sensOr first
  7. #7 Re: 2000 gtp died
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Could also be fuel system. My factory fuel sending unit broke off in the tank and migrated around the tank for a few weeks before I figured it out. I thought I just had a wonky fuel level sensor.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  8. #8 Re: 2000 gtp died
    Jun 2010
    Bakersfield, CA
    So, I had let this vehicle sit for a couple months, due to no time tear into it. Got on it this weekend and replaced the Crank position sensor. Driven for 2 days now with no issue. I'm pretty confident that was it. Just wanted to update this thread in case someone with a similar problem comes across it in a search. The low coolant sensor is a separate issue and I'm sure a new sensor will fix that as well.
  9. #9 Re: 2000 gtp died
    Yeah..those get gunked up and then act up.
  1. Car died?!
    By Pure2sin in forum General Grand Prix Discussion
    Last Post: 07-15-2012, 04:09 PM
  2. I died...
    By gtpsleeper in forum Track Sessions and Kills
    Last Post: 02-15-2012, 10:56 PM
  3. My car died
    By GPGTkid01 in forum General Tech Discussion
    Last Post: 10-20-2009, 08:25 PM
  4. died
    By Cjs02GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2009, 08:46 PM
  5. died
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2009, 06:21 AM
