Thread: Headers - Install Opinions
Results 41 to 60 of 79
  1. #41 Re: Headers - Install Opinions
    My sd's were much better than my zzp to install. I'd do sd's if I had to do it again but I sold my sd's.
  2. #42 Re: Headers - Install Opinions
    GT Level Member hammerline81's Avatar
    Apr 2013
    Saskatoon, SK
    Well I might be rigging up some SD's again..
    Sent from my SM-G900W8 using Tapatalk
    2004 Grand Prix GTP Comp G
  3. #43 Re: Headers - Install Opinions
    I tend to like to bring in headers from below and never really have much trouble with them. ZZP's were a little tighter on room because of the crossover situation. Got it to wiggle in though. SD's are a cakewalk from underneath. Although I really like what Red did with that pipe and could see coming in from above with that setup.
  4. #44 Re: Headers - Install Opinions
    Oct 2011
    Toledo, OH
    40-45 should work
    Yeah I found it to be about in between there as well. Probably some variation in the headers though. I'm pretty sure it's less than 45 but that would have worked with how I did my flex. Same as RED, 2 bolts and v-band to remove flex which also allows a little play in your angles.
    7"
  5. #45 Re: Headers - Install Opinions
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    My sd crossover was a huge pain took 3 guys hours to fit that crossover in and a few days ago I saw it is still leakibg where the front header goes into the cross over.. smh
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  6. #46 Re: Headers - Install Opinions
    That's something I don't understand...I've done a ton of header installs and never fought them like some of you guys mention. Makes me wonder if they put a wrong crossover in with some of the kits or something.
  7. #47 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    No clue but it's seriously not fun.. when SD headers drop in price I'll get another set and I'll modify them. I really hope I don't have to fight with the crossover like I did before. There's no way I could install the headers myself if that happens again.
  8. #48 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    Im speaking with the sellers on ebay about their headers and they're really interested in the modifications that have been done with their headers. If you guys don't mind, I've sent them some of your modifications so that they can see what improvements need to be made.
  9. #49 Re: Headers - Install Opinions
    Apr 2012
    Goderich, Ontario
    Quote Originally Posted by hammerline81 View Post
    where's that like button
    -Paul Walker
  10. #50 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    Lol they're sending the pictures to thier manufacturer to come up with a better design for the next batch.
  11. #51 Re: Headers - Install Opinions
    Good now hopefully they don't jack up the price to much
    04 Comp G.
  12. #52 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    Haha good point. I told them that was there huge selling point
  13. #53 Re: Headers - Install Opinions
    I wouldn't care if it was a minor increase but if they get outrageous then screw that.
    04 Comp G.
  14. #54 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    Yeah, I'll second that.
  15. #55 Re: Headers - Install Opinions
    Apr 2012
    Goderich, Ontario
    If they stay around the same price they are now then I'm gona spend a lil extra and buy SLP's. Cheapest I'v found so far is from Thrasher.
    -Paul Walker
  16. #56 Re: Headers - Install Opinions
    Florida
    I guess i have been lucky with my headers. I installed them when i did the engine swap and then had to deal with them again when i did the topswap. not having a head in the car makes install easier and so does putting an engine that already has the headers on it...
  17. #57 Re: Headers - Install Opinions
    Florida
    When I installed mine with a friend we did it from the top,it wasn't too bad took 30min worth of angles and fighting lol. I did have to go to exhaust shop and have them open the front header/crossover section since it just wouldn't slide in. I am hating this dip in the dp though I've knocked into a few speed bumps and scraped some low dips,might have it modified sooner or later.
  18. #58 Re: Headers - Install Opinions
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I hope they let you know if they can do it along with an adjusted price. Thats awesome they got interested in it.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  19. #59 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    I'll email them again in the future just to keep tabs onto what's going on and I'll for surely post it to let you all know. Yeah I thought it was cool that they were open to ideas
  20. #60 Re: Headers - Install Opinions
    id love to know who and why they thought a drain trap was a good idea to put in the down pipe...........if they re worked them they would use less material really. and should be a quicker build, so lets hope the price stays the same.
  1. Need Someone To Install My Headers
    By GTPcompG05 in forum Northeast
    Last Post: 05-09-2012, 06:04 AM
  2. Opinions on these ebay headers (not SpeedDaddy's)
    By Chitown Racer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2011, 12:27 PM
  3. opinions on xm radio install
    By RyanL in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2010, 11:35 AM
  4. anyone know how to install headers?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 05:54 AM
