Thread: Headers - Install Opinions
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 79
  1. #1 Headers - Install Opinions
    GT Level Member hammerline81's Avatar
    Apr 2013
    Saskatoon, SK
    Grand Prix
    2004 Grand Prix GTP Comp G
  2. #2 Re: Headers - Install Opinions
    Wht
    04 Comp G.
  3. #3 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    I'm using tapatalk on my new galaxy s5... totally messed up this thread... sorry... SMFH! I figured it out though.
    Sent from my SM-G900W8 using Tapatalk
  4. #4 Re: Headers - Install Opinions
    So, what are we figuring out?
  5. #5 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    I made another thread. But I just wanna know how zzp headers are to install and the quality. Those or other brands of that caliber. I've put in SD headers, bent the transmission dipstick and after a while of figuring out to why my car lit up on fire it was because I bent the stick enough to have a pin sized hole that shot just enough oil out... I want to stay away from that with this Comp G I'm rebuilding.
  6. #6 Re: Headers - Install Opinions
    And I know you know how to use the search feature... Because just about every single header question has been answered multiple times
    04 Comp G.
  7. #7 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    So there's a thread that compares the install of SD and ZZP's? Sorry... I haven't found that.
  8. #8 Re: Headers - Install Opinions
    Not exactly.. Headers are headers they both will install the same one may just be slightly easier.. Your getting a slightly bigger primaries with ZZP. IMO don't eliminate SDs because of your error. Next time be more careful.
    04 Comp G.
  9. #9 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    Yeah that's true to be careful; I've learnt since that car is no longer here with me. I just seen that ZZP said it's possible to install without removal and bending.
    Plus... to do the SD's right, you gotta do the whole jig process and the flex pipe... I believe my bill came out to 600 all together.
  10. #10 Re: Headers - Install Opinions
    Jig... Scrap wood
    Flex pipe...30 bucks
    You modify them yourself
    Welding...$50
    O2 extension... $20
    Headers $220
    Yea far from $600
    04 Comp G.
  11. #11 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    Lol I'm Canadian... we have garbage prices on absolutely everything. It was minimum $100 for a welder..
  12. #12 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    But I put new gaskets and everything when I was doing that job... I don't know.. aren't you running slp?
  13. #13 Re: Headers - Install Opinions
    Nope Modified SDS. I also replaced the manifold gaskets with oem which were $20. New oem flange gasket which were like $60 and modified them slightly different so I put a little more into it but not $600.
    04 Comp G.
  14. #14 Re: Headers - Install Opinions
    Pictures sucks but you can probably get the point
    04 Comp G.
  15. #15 Re: Headers - Install Opinions
    I posted up how to install, my feelings on all the installs and things to do. Never ever said to bend dipstick and light up a car. That one is all you.
  16. #16 Re: Headers - Install Opinions
    Yea and I never had to bend my dipstick
    04 Comp G.
  17. #17 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    I saw that bill, you said it should take like 6 hours? I can't exactly remember it all it's been a while. But yeah... I had the engine strapped right to the front(without the front manifold there) and we just couldn't get them in.
    Did you guys have issues with the crossover that went over the transmission? That took the longest. I had me and two other guys trying too get that in... took a tire bar and punch to get it to go... it was unreal tight...
  18. #18 Re: Headers - Install Opinions
    Apr 2013
    Saskatoon, SK
    Red; you did a really great job by the pics you posted
  19. #19 Re: Headers - Install Opinions
    Thanks. Well worth it no more clearance issues. I didn't have any crossover issues..it went in without a issue.
    04 Comp G.
  20. #20 Re: Headers - Install Opinions
    you can buy 3 inch pipe with the same angle red has in his pics. then have it cut and welded in. Reds looks real smooth, no trap at all.
    any reason no one seems to put a V clamp on both sides of the flex pipe? id think that would be the easy way to change it when it does fail. all you would need is a new flex with the v band ends welded on right?
  1. Need Someone To Install My Headers
    By GTPcompG05 in forum Northeast
    Last Post: 05-09-2012, 06:04 AM
  2. Opinions on these ebay headers (not SpeedDaddy's)
    By Chitown Racer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2011, 12:27 PM
  3. opinions on xm radio install
    By RyanL in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2010, 11:35 AM
  4. anyone know how to install headers?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 05:54 AM
