Finally managed to install my Aeroforce Gauge after much deliberation with regards to position, I ended up mounting it in the cubby area.
As I have an 02 GTP this seemed like the best alternative, I removed the center console trim bezel and drilled a 2.125" hole with a hole saw
and wrapped some foam tape around the outside diameter of the gauge which gave a nice snug fit, then ran an additional power wire with the
help of add a fuse and tucked the wire neatly behind the carpet and plugged in the OBD II cable, its working just fine and gives good visual,
more importantly is out of the way of a crime opportunity.
Would most definitely recommend this gauge even if you are lightly modded, purchased mine from Intense.
