Thread: 05 gtp oil pan replacement
Results 1 to 4 of 4
  1. #1 05 gtp oil pan replacement
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Ok I'm gonna be replacing my oil pan since it's cracked around where the bolt goes for the motor mount bracket. Figured it wouldn't be to bad since in pulling my bent subframe out for replacement. Only thing I'm trying to figure out is what about the oil pan gasket? When I look it up on eBay all I get is this http://www.ebay.com/itm/350830275251 is that all I need?
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: 05 gtp oil pan replacement
    No, the aluminum pan has no gasket on the GP. It uses an engine sealant, usually gray.
  3. #3 Re: 05 gtp oil pan replacement
    stanford Ky
    So all I need is a engine sealer? What kind is recommended? I'm used to regular gaskets so I'm a little worried about it leaking after I get everything all put back together
    99 gtp- sold
  4. #4 Re: 05 gtp oil pan replacement
  1. Timing Chain/Belt replacement? Tension-er replacement?
    By void33 in forum General Tech Discussion
    Last Post: 02-21-2014, 02:34 PM
  2. VSS replacement
    By rowekmr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2013, 08:37 AM
  3. Amp replacement
    By whatthekrapp in forum Audio, Security & Visual Electronics
    Last Post: 01-12-2013, 09:43 AM
  4. oil pan replacement
    By frankjc in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2011, 10:29 AM
  5. anybody know where i can get a replacement.....?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 08:46 AM
