Thread: No A/C? Help!
Results 1 to 13 of 13
  1. #1 No A/C? Help!
    Apr 2014
    Minneapolis
    Hey guys. When I first bought the car, which was in the winter, I couldn't test if the A/C actually worked or not. Now that it's 70 degrees and sunny, I turned it on and no cold air comes out. I put some new R134a refrigerant in the car, but still, no cold air. When the A/C and/or the front/rear defrost is on, an obnoxious cranking/vibrating sound coming from the A/C compressor. At least that's where I think the sound is coming from. Any ideas? Thanks
    Brent's Boat with Boost - 00' GTP | 3" Downpipe w/cat | U-bend Delete | Polyurethane Motor Mounts | K&N Cold Air Intake |180* Thermostat | Tuned PCM | Powerlog Front Exhaust Manifold | 3.5" Supercharger Pulley | Autolite 104 Spark Plugs | TransGo Shift Kit
  2. #2 Re: No A/C? Help!
    Is the compressor spinning? If it's making noise the compressor is probably bad.
  3. #3 Re: No A/C? Help!
    May 2014
    Pittsburgh
    I know you can buy a/c kits from ebay, but I have never installed one myself
    Had a 94 Formula years ago, and the compressor stopped working in it, a garage I took it to said I would need a compressor and a drier, and I would be looking at $800 if they replaced it and charged it up.
  4. #4 Re: No A/C? Help!
    Apr 2014
    Minneapolis
    The compressor is spinning, and when it does it makes that grinding sound.
  5. #5 Re: No A/C? Help!
    If it's making noise then compressor is probably bad
    04 Comp G.
  6. #6 Re: No A/C? Help!
    Quote Originally Posted by knightp25 View Post
    and this ^^^^^ is what should be done once again. if your up to it you can change all the parts then have a shop vac test it and fill it for you. this way you can save on all that labor.
  7. #7 Re: No A/C? Help!
    FWIW when you do a compressor, drier is expected and so is an orifice tube.
    I'd get the $10 seal kit, and do all those parts. Then have a shop vac/fill as suggested.
  8. #8 Re: No A/C? Help!
    Aug 2008
    KCMO
    Where is the orifice tube located? My compressor kicks on and sounds good but it just blows hot air. I charged it last sumer with 20oz of a/c pro but it was back to blowing hot air after 2 days of driving.
  9. #9 Re: No A/C? Help!
    You have a leak then
  10. #10 Re: No A/C? Help!
    look for a wet oily mess on one of the a/c lines. most of the time you find a dirty connection its the leak.
  11. #11 Re: No A/C? Help!
    Apr 2014
    CT
    carl dye test the system. valve cores and compressor leaks very common. some times if leak is bad enough u can hear it. you can also put ur thumb over the valves to feel for back pressure. soapy water in spray bottle is your friend too.
    m7x if you repair system with ebay kit be sure to properly flush evaporator and lines. if theres crap in the system u may have to replace the condenser. you cant properly flush a parallel flow condenser.
  12. #12 Re: No A/C? Help!
    Aug 2008
    KCMO
    Where are these valves you speak of so I can check them? I'm going out to put in the orifice tube right now to see if its clogged. I will also swing by the parts store tomorrow and pick up the a/c seal kit as well.
  13. #13 Re: No A/C? Help!
    Apr 2014
    CT
    The valves where you check the pressures and fill system.
    Don't forget any part you replace like the drier/accumulator you must measure how much oil comes out of it and replace it with the new one. unless you plan on flushing the whole system including evaporator at which point you need to put back the full amount of oil.
