Thread: need help on two issues
Results 1 to 5 of 5
  1. #1 need help on two issues
    Apr 2014
    CT
    First off I have a hum from the rear while driving it changes in intensity when hitting bumps or turning. Wheel bearing? Do I need a special tool for parking brake?
    Second issue. Fuel pressure bleeds off fast when car is off. Could this be regulator or leaky injector? Its a 2001 gt. The car runs fine but sometimes makes a dieseling sound when starting for just a split second.
  2. #2 Re: need help on two issues
    #1 .. I don't remember what year you have. Nothing is really a special tool in doing the bearing (which sounds about right). Worst part of the bearing on a 97-03 is the parking brake piece on the back that bolts into the bearing. Crusty bolts.
    #2 There is a check valve in the pump that does this.. most of the time you'd never test it or know it's faulty. It's very common.
  3. #3 Re: need help on two issues
    Apr 2014
    CT
    So should I just wait a second with key on b4 starting. The 01 has fuel regulator on the rail on top of engine. Shouldn't it not leak out pressure beyond that point?
  4. #4 Re: need help on two issues
    If the check valve in the pump is bad, the regulator can't fix that.
  5. #5 Re: need help on two issues
    Apr 2014
    CT
    OK thx I wasn't sure where the pressure was held. It will have yo stay that way for awhile then and ill order a timken wheel bearing.
  1. EGR issues. Need help
    By IMPALADAKID in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2012, 10:49 AM
  2. I have issues
    By BillBoost37 in forum The Rant Forum
    Last Post: 01-06-2012, 04:10 PM
  3. a/c issues: help please
    By us Sgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 10:33 AM
  4. 05 pcm issues in 07
    By vailskier3 in forum PCM Tuning
    Last Post: 03-07-2010, 06:34 PM
  5. A/C Issues
    By ReaperRob in forum General Tech Discussion
    Last Post: 08-10-2009, 09:55 PM
