Thread: Anyone remove the vacuum line from FPR to boost bypass solenoid?
Results 1 to 6 of 6
97AutoXVette Anyone remove the vacuum line... 05-11-2014, 08:32 PM
Scottydoggs Re: Anyone remove the vacuum... 05-11-2014, 08:38 PM
97AutoXVette Re: Anyone remove the vacuum... 05-11-2014, 08:39 PM
Scottydoggs Re: Anyone remove the vacuum... 05-11-2014, 08:42 PM
97AutoXVette Re: Anyone remove the vacuum... 05-11-2014, 08:45 PM
Scottydoggs Re: Anyone remove the vacuum... 05-11-2014, 08:48 PM
  1. #1 Anyone remove the vacuum line from FPR to boost bypass solenoid?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Has anyone removed the vacuum line that tees from the fuel pressure regulator over to the boost bypass electronic solenoid? Just wondering if the fuel pressure regulator still functions the exact same with and without the vacuum line (I'd cap off that side of the T)
    been doing some vacuum line "remodeling" lately...
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Anyone remove the vacuum line from FPR to boost bypass solenoid?
    you need that.
    you could run a line from the fpr to under the snout, then loop the by pass vac line around the back under the tb and tie it back in by the map sensor.
  3. #3 Re: Anyone remove the vacuum line from FPR to boost bypass solenoid?
    Mar 2014
    Cincinnati, OH
    Wondering why it is needed though?? That line is only used when the solenoid is commanding boost bleed using the BBV right?
    2002 GTP sedan:
  4. #4 Re: Anyone remove the vacuum line from FPR to boost bypass solenoid?
    idk. but its there for a reason, id leave one in place. it wont matter how long the line is. as long as you have one.
  5. #5 Re: Anyone remove the vacuum line from FPR to boost bypass solenoid?
    Mar 2014
    Cincinnati, OH
    Can say, I do like the idea of routing behind the blower just Teeing off of the MAP sensor line
    2002 GTP sedan:
  6. #6 Re: Anyone remove the vacuum line from FPR to boost bypass solenoid?
    maybe find a few wire tuck threads and see if you can see where they hid it in their pics.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. boost bypass valve solenoid wiring
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 09:59 PM
  3. boost bypass valve? vaccum line?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 10:46 AM
  4. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
