Here is the deal, i have an issue with my gtp 2001. It's intermittent, but it make me angry as **** lol.
Sometime when i start my car,with the climate control on position 1 2 3 or 4, my automatic headlights are not working, my DIC,defrost,and climate control neighter. And then, sometime 10 minutes later or 2 or 5,i hear something Under my sterring column make click click, and then all of this start to work fine, but if i turn off the car i have the same issue to deal with.
Also, if i put my climate control on position 5 before turning my key ton "on" position, all the stuff is working well (i heard there were a protention on this so the 5 position bypass a relay etc etc) and by that, it's a half an half chance if i turn the button to lower position,all the things ( headlights,DIC,climate,defrost ... ) will shut down..
NOW, on the net, it all come to one response, the ignition switch, can someone confirm this?, and if so, does someone have a picture of it in place, and is it true it's corrosion on the pins and i just have to clean the pins?
i'm about to put the car on fire since i'm tired of this haha Help please
