change your ignition switch. or clean the contacts. becareful when taking it apart if you try. it has springs in it. and it must be taken apart a certain way. there is a ring where the input is from the key tumbler. you must take that ring off first before trying to separate the switch otherwise youll break the housing. Its just snap clips on the side of the switch that you pry up with a flat blade screw driver. Take off the top piece first ( the piece that holds the return springs for the switches. Once you get inside you will see where you have to clean the contacts. You also need a reverse torx bit to get some screws out. I was able to get them out with needle nose pliers but it was a biotch.
