the temp sensor is under the t stat in the lim. its plug is a short harness that can bake on the cross over pipe. so those wires could be bad, or the temp sensor could be bad.
the fans work? and the temp gauge needle seem to work ok when its all warmed up and running?
yes fans work gauge works like it should I will check the wires you are probably right. what is the best way to check for a vacuum leak and also could this be fuel related.?
