bad ignition switch ( known issue on these cars).
I went through this with a 2001. could not figure out what was going on. the information center would fade away or go off. the heat would only work on high setting and eventually the starter would not engage. So more than one contact on mine was going bad. I pulled it apart after changing it and sure enough the little lever contacts were all burnt at the tips.
