Thread: car died seems like a fuel problem help please need input
Results 1 to 13 of 13
  1. #1 car died seems like a fuel problem help please need input
    Apr 2013
    canada
    Hello fellow grand prix owners had a problem with car today was driving perfectly fine, i ran the fuel tank low and put in about 15 litres drove about 80 km then on way how had to go up a steep hill very slow cause an old man driving in fron about a block later the car started to die and sputter i pulled over by a gas station and thought i had water in gas so put in some moregas and gas line antifreeze no go let it sit and then it started but was chugging like water in gas let it idle then about 2 min it died tried starting again no go waited about 6 7 min tried again started and chugged played with gas pedal it idleed then again after couple of min chugged and died it keeps repeatting this now , i am thinking really bad gas or did i pick up dirt and its clogging fuel filter or fuel pump or do you think plugged injectors or could it be something else please help...!!!
  2. #2 Re: car died seems like a fuel problem help please need input
    Does it run just fine if you always keep your foot in it?
    Bad gas or water in the gas would likely not even allow it to keep running well with the gas pedal pushed down some.
    Perhaps try unplugging the MAF sensor and see if the idle returns to normal.
  3. #3 Re: car died seems like a fuel problem help please need input
    Mercer, Pa
    Could be your fuel pump. Do you have a pressure gauge or way to check pressure.
  4. #4 Re: car died seems like a fuel problem help please need input
    Apr 2013
    canada
    no havent checked the fuel pump yet gotta wait till tommorow, map sensor huh mhmm give that a try
  5. #5 Re: car died seems like a fuel problem help please need input
    Apr 2013
    canada
    well just walked 2 blocks to check my car it started right up and i drove home and let it idle for 10 min nothing weird.or what whats the prognosis..
  6. #6 Re: car died seems like a fuel problem help please need input
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    It probably was water. After filling up the water would have been dispersed in the gas. After letting it sit, the water would have pooled at the bottom of the tank but you put in ethanol which absorbed the water. Adding ethanol isn't an instant fix so letting it sit for a few hours will give it time to mix and work. Call the gas station and complain. If they own up to the issue they will reimburse you.
  7. #7 Re: car died seems like a fuel problem help please need input
    Apr 2013
    canada
    well not sure whats gong on now started it up today and it started but its running very rough and if u put it in drive it has no power ,kinda chugging, but will idle...what the hell is going on im saying....plugged fuel filter not enough psi for the engine..did dirt now get into injectors did i blow a plug,,cant work on it till tommorow going to do a fuel line pressure test if not good change filter, if its fine im thinking changing my plugs maybe one fouled up...any ideas on all the symptoms from my first post till now would be helpful thanks...
  8. #8 Re: car died seems like a fuel problem help please need input
    Apr 2013
    canada
    anyone help please any ideas tried to get fuel filter off today rusted on bad and dont have the tools to cut lines and pout a universal one on...it runs the car but like starving for gas or maybe not firing rightr cant telll waiting till tommorow guess might haver to take it to a shop...any help
  9. #9 Re: car died seems like a fuel problem help please need input
    Eau Claire, WI
    What year is your car, and what exactly have you done already?
    FYI, the fuel filter is in a terrible spot and rusts bad. I soaked mine in PB blaster, every day, for a few days before taking it off. Then I coated in the fittings in grease to repel water after putting it together.
  10. #10 Re: car died seems like a fuel problem help please need input
    Apr 2013
    canada
    well bugsy i have checked the fuel pressure it seems fine now there is lots of gas coming out exhaust the injectors are working and there resistance seems fine.. now the car has thrown codes cause oif my playing around lean code prob because of playing with an injector i screwed with wire was bad so fixed it and maf code since i disconnected it while running, havent got any other codes show up yet so im not sure whats going on checking plugs next and wires but how do u check the coils in this car oh ya 97 grandprix gtp i see how you take them off but there enclosed so how do you check the terminals..
  11. #11 Re: car died seems like a fuel problem help please need input
    Nov 2013
    pittsfield ma. 01201
    Had same problem with my truck used some gas line anti freeze but it took about three days to work. Runs fine now.
  12. #12 Re: car died seems like a fuel problem help please need input
    Eau Claire, WI
    I can't look past the fact this started right after you got gas. What I would do is just get rid of that gas.
    1) Get a simple siphon kit and pump it all out.
    or
    2) Unhook the fuel filter and slip a rubber line over the "output" of it. Jump a wire to the pump relay and let the pump do the work for you.
    When you think you have the tank as empty as possible, dump in a bottle of IsoHEAT and a couple of gallons of gas. Wait a day and top the tank off with good gas.
  13. #13 Re: car died seems like a fuel problem help please need input
    Apr 2013
    canada
    well found out what the problem was it was an ignition coil failed thanks to all
  1. Fuel gauge problem
    By 1995brian in forum General Grand Prix Discussion
    Last Post: 01-29-2013, 05:49 PM
  2. fuel problem???
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2012, 06:36 AM
  3. Fuel Problem
    By sonic7 in forum General Grand Prix Discussion
    Last Post: 03-08-2012, 06:05 PM
  4. Fuel problem
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2010, 10:01 PM
  5. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
