Thread: Wideband installation help please
Results 1 to 7 of 7
  1. #1 Wideband installation help please
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I have found the grommet through the passenger side firewall where the wire harness and vaccuum line are routed through. My question is what did you guys do from there? Remove part of the grommet to fit the sensor wires through? Drill an additional hole?
    Thanks!
  2. #2 Re: Wideband installation help please
    Mar 2012
    NC
    I used the grommet on the D/S by the brake booster.
  3. #3 Re: Wideband installation help please
    Just shoved it in there.
    That's what she said
    04 Comp G.
  4. #4 Re: Wideband installation help please
    Mar 2014
    Cincinnati, OH
    haha.. I will give it my best shot.
  5. #5 Re: Wideband installation help please
    May 2012
    Where winter never ends
    Get a wire coat hanger, untwist the top, fold it out flat, electrical tape the wire to the coat hanger 1/3 of the way up, stick the not taped end of the hanger through the hole, guide it through from both ends.
    2000 Regal - Winter Beater
  6. #6 Re: Wideband installation help please
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Adecker View Post
    Perfect. I am going to try to get the wires through that grommet this evening
  7. #7 Re: Wideband installation help please
    Mar 2014
    Cincinnati, OH
    Got the wideband installed and thought I would share:
    I ended up going through the grommet on the floor in front of the passenger seat. There is a rubber grommet in the floor board just in front of the passenger seat. Pulled out the grommet and modified it for a wire, and cut a small slot in the carpet for the sensor wire. Then routed the wire up through the center consol next to the shifter and then up behind the glovebox to get to the drop power source. Overall, worked out pretty well. I can post up some pics soon.
  1. Wideband PID
    By Sandman in forum PCM Tuning
    Last Post: 03-08-2011, 09:24 AM
  2. Wideband
    By Wrongwayislost77 in forum PCM Tuning
    Last Post: 02-28-2011, 12:51 PM
  3. AEM Wideband o2
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 04:23 PM
  4. Wideband AFR where should....?
    By GTP4 in forum PCM Tuning
    Last Post: 04-21-2009, 11:57 AM
