Thread: Modification priorities different for a desert car?
Results 1 to 2 of 2
  1. #1 Modification priorities different for a desert car?
    Mar 2014
    Tucson
    Hello!
    I recently purchased a 2000 GTP sedan, and I'm curious if my modification priorities should be different due to living in a desert climate. Tucson, specifically.
    So far, the things I've done have been mostly maintenance/tune-up items:
    Clean throttlebody
    Air filter - Fram paper
    Fuel filter - Fram stock replacememt
    Plugs - AC Delco 41-993 Iridium
    Wires - AC Delco stock replacements
    Tstat - AC Delco 180°
    PVC valve - AC Delco stock replacement
    RH Front hub/bearing - Timken 513121
    CV Shafts, both - A1 Cardone
    Output shaft seals, both - Timken
    Motor mount - Solid DEA
    Torque thrust mounts, both - Anchor (also flipped)
    And had the EBTCM repaired
    Pretty sure previous owner drove around way too long on the broken mount and took out half the items on that list. Just wanted to make sure I had the basics covered before anything else.
    Anyhow, My first purchases were going to be the Aeroforce scan guage, and an AEM wideband. After that, I'm unsure what would get me the most HP/$. Should I do the standard list (CAI, pulley, headers...)
    OR, because of my higher ambient temps, should I hold off and save my nickles for the short stack intercooler? (Or something else?)
    I would love to start throwing parts at this ASAP, but if they're only going to get me more KR, I don't want to do that. Just like everyone else here, I want to make every dollar count. Would like to hear opinions on this subject.
    Here's what I'm starting with:
    [IMG][/IMG]
  2. #2 Re: Modification priorities different for a desert car?
    Your climate doesnt really change a whole lot if anything when it comes to modding.
    Personal preference for me is doing somesort of exhaust mod first. Be it headers or a plog/downpipe combo. Then once that it done you can explore other things such as a pulley drop to maybe a 3.6 to 3.4, always depends on what the car likes. Running the highest octane you can aswell. A in car tune is what I prefer over a canned mail order tune, that can do alot to help with how the car drives and reacts to the mods.
  1. Desert Fox transmission cooler install.....and FMHE???
    By copgtp in forum General Tech Discussion
    Last Post: 06-25-2011, 09:52 PM
  2. the desert
    By redlinepontiac in forum Off Topic Discussion
    Last Post: 04-05-2011, 09:58 PM
  3. 1$ modification !
    By XAtlantisX in forum Visual/Body Modifications
    Last Post: 07-04-2010, 04:28 AM
  4. Desert fox trans cooler kit uses B&M rad?
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-21-2009, 12:53 AM
  5. "Desert Fox" tranny cooler
    Last Post: 08-12-2009, 03:15 PM
