Thread: 98 GTP Oil Pan Gasket Replacement?
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: 98 GTP Oil Pan Gasket Replacement?
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Ok and one last question for you guys before I mess with the trans pan and stuff. Where is the best place to jack and place jack stands for the front if the spot behind the wheels is a little rusty and I dont trust it?
    Sent from my SCH-I545 using Tapatalk
  2. #22 Re: 98 GTP Oil Pan Gasket Replacement?
    you can use car ramps to service the tranny, or put the jack stands on the sides of the sub frame. (near the lca's) you can jack the whole front end up from the middle front of the sub frame, then place the jack stands and lower the jack.
  3. #23 Re: 98 GTP Oil Pan Gasket Replacement?
    Feb 2010
    TN
    I was quoted $600 back in 2003
  1. LIM Gasket Replacement. what else while I'm here
    By Yarbeau in forum General Tech Discussion
    Last Post: 02-24-2013, 11:59 AM
  2. oil pan gasket replacement
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2012, 11:45 AM
  3. LIM Gasket Replacement
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2011, 11:10 AM
  4. Oil Pan Gasket Replacement
    By m17davis in forum General Tech Discussion
    Last Post: 02-18-2011, 01:49 PM
  5. Oil Pan Gasket Replacement
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2008, 01:18 PM
