If its just then trans pan leaking then go get a filter and gasket and trans fluid. Remove pan, remove filtee, clean mating surface really good, clean trans pan good, put on new gasket and bolt back up done. Re add 7 quarts of new fluid, starr car cycle through all gears while parked. Check fluid level, add as needed. Should take 8 or so total.
Sent from my Galaxy Tab 3 8.0
