Thread: Steering Problem
Results 1 to 7 of 7
  1. #1 Steering Problem
    SE Level Member GrandPrixMI's Avatar
    Mar 2014
    SouthWest Michigan
    Whenever I turn the steering wheel to either the left or right wheel locks, and I am just letting the car roll and idle (in drive) the steering wheel tends to jerk back the other direction just a little, and the back to the wheel lock and over and over again.. It's like the tires are slipping on rocks or something. Could this be bad tie rod ends or something with the power steering? And sorry if I didn't explain well, if you need more info I'll try to explain it better. I've noticed it does this on any kind of road surface I am on.
    2000 Grand Prix GT Coupe - 2 12" Kickers 2000W Hifonics Amp, K&N CAI, 155k Miles
  2. #2 Re: Steering Problem
    St. Louis
    Check the level of your power steering fluid. If it's full, then I'd say the rack or pump is shot. Would also help to know what year GP you have.
  3. #3 Re: Steering Problem
    Mar 2014
    SouthWest Michigan
    I have a 2000 GT Coupe. And I will try to, thats near the rear of the engine right?
  4. #4 Re: Steering Problem
    St. Louis
    Yep, the resivoir for the pump is located under the alt. Just follow around the backside of the alt and down between the firewall and you should be able to reach it.
  5. #5 Re: Steering Problem
    Mar 2014
    SouthWest Michigan
    Alright, I'll be doing that tomorrow when it's light outside. Hopefully that's the problem. Thank you.
  6. #6 Re: Steering Problem
    HUDSON
    The problem is...holding the steering at the wheel lock/stop. Try not to hold the steering all the way to either side, when driving in real tight situations turn the wheel as far as needed and if you hit the lock/stop turn the wheel slightly the other way so your not holding it their, as damage to the steering system may result from that.
  7. #7 Re: Steering Problem
    Mar 2014
    SouthWest Michigan
    I really don't try to hit the wheel locks, but everytime I do hit them it has this problem. I don't need any problems with the car lol
  1. Power Steering Problem
    By xXTeamArcticXx in forum Engine
    Last Post: 03-02-2012, 08:32 PM
  2. Power Steering problem
    By jhw in forum Introductions/Noob Questions
    Last Post: 01-07-2011, 11:16 PM
  3. steering problem
    By GTP Ryan in forum General Tech Discussion
    Last Post: 12-06-2009, 04:40 PM
  4. steering problem
    By stanggreg90 in forum General Tech Discussion
    Last Post: 10-16-2009, 10:05 AM
  5. Steering Problem Please Help
    By 2000grandprixGT in forum General Tech Discussion
    Last Post: 03-08-2008, 02:00 PM
