Thread: having heads-up-display problems 2000 grand prix GTP PLEASE HELP
Results 1 to 3 of 3
  1. #1 having heads-up-display problems 2000 grand prix GTP PLEASE HELP
    Oct 2013
    Chicago
    My heads up display started to show random numbers when it was on.... 1-150 just random numbers, this started a month or two ago, i want to fix this because it helps me not speed, what do i replace EXACTLY?
  2. #2 Re: having heads-up-display problems 2000 grand prix GTP PLEASE HELP
    I wonder if that is because of a poor signal from the VSS on the transmission.
  3. #3 Re: having heads-up-display problems 2000 grand prix GTP PLEASE HELP
    SE Level Member chatbreaker's Avatar
    Mar 2014
    midwest
    Could be VSS, but my car did the exact same thing after I swapped the engine, and the random numbers would change with the engine's RPM. turned out to be a faulty ground.
    Check your ground connections on the front of the engine by the bellhousing. If those are good, try unplugging and cleaning the VSS connector inside the passenger side wheel well, then plug it back in. If the problem is still there, try replacing the VSS, and if that doesn't fix it, you might have to replace the HUD.
    Most electrical problems are caused by poor power/ground issues - when hooking up wires, remember this: clean and bright, nice and tight.
  1. Dash light and Heads up display won't work on 97 Grand Prix GT
    By PANTHERFAN89 in forum General Grand Prix Discussion
    Last Post: 09-13-2012, 03:18 PM
  2. Dash Light and Heads up display won't work on 97 Grand Prix gt
    Last Post: 08-04-2012, 04:08 PM
  3. WANTED - 2004+ heads up display trim panel for grand prix
    By GTX in forum Wanted To Buy - Parts
    Last Post: 03-07-2012, 12:08 AM
