Thread: Chasing P0300
Results 1 to 11 of 11
  1. #1 Chasing P0300
    SE Level Member 97whtGTP's Avatar
    Apr 2011
    Sicklerville, NJ
    Hey guys, hoping you can help me out here.
    Past couple days I have been getting a recurring P0300 DTC.
    Car is a 2004 GTP Comp G with 96k
    New parts/tests:
    Plugs Delco
    Wires Delco
    Coils removed cleaned and tested
    ICM cleaned and tested
    All of this was dont after receiving the code the first time
    Symptoms:
    Car runs pretty much normal, slight rough idle, seems to loose power under heavy load
    Hooked scanner up (Actron CP9145) I know its not the best but it's all I have and here is what the live data reads as it shows on screen:
    This was at a fully warmed up idle from a cold start and with code cleared. In closed loop.
    ABSLT TPS(%) 3.5
    IDLE 700-780 (fluctuates in this range)
    CAL LOAD(%) 1.6
    MAF(LB/M) 0.65
    MAP("HG) 10.9
    COOLANT 194
    IAT 91
    IGN ADV(DEG) 18-22.5 (fluctuates in this range)
    LT FTRM1(%) -5.5
    ST FTRM1(%) 0.0-4 (fluctuates in this range)
    02S11(V) 0.160-9.45 (cycles up and down)
    ST FTRM11(%) 0.0-3.1 (fluctuates in this range)
    02S12(V) 0.850 (stays steady with very little changes
    Using this can anyone point me in a direction I haven't gone yet?
    I greatly appreciate any and all advice.
    1997 GTP, Dynotech Stage 2 Trans, 3k Stall, Ported Blower, SLP CAI, 3.4, Denso, FP hotwire, 2.5 downpipe, Magnaflow cat, Slp Loudmouth SS, Dynomax Bullet, Tune - LONG GONE
    2004 GTP Comp-G, Wizair CAI
  2. #2 Re: Chasing P0300
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    can be poor electrical connection to coil igniter, to an injector poor wiring connection to injectors or fuel pressure
  3. #3 Re: Chasing P0300
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Also your rear o2 bias voltage should be changing up and down. Pegged rich like that could indicate something is going on. Sorry im not being more specific, Im just pointing out a few oddity's.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  4. #4 Re: Chasing P0300
    Apr 2011
    Sicklerville, NJ
    Quote Originally Posted by frosty View Post
    The one that is pegged is labeled O2S12. Safe to assume the reader is calling this bank 1 sensor 2 which would make it the downstream correct? And if it is could I possibly be looking at a dying Cat?
  5. #5 Re: Chasing P0300
    Apr 2011
    South Dakota
    Quote Originally Posted by lewis1952 View Post
    Fuel trims are normal and there are no injector codes so we can probably eliminate injector connection issues, He also said that he cleaned the icm plate and coils / basically tuned up the entire ignition system.
    I love Decker<3
  6. #6 Re: Chasing P0300
    Apr 2011
    Sicklerville, NJ
    Taken from ls1tech.com credit to joecar
    Vacuum is related to MAP as follows: VAC = BARO - MAP
    BARO is appox 29.9 inHg at sea level
    Your MAP is 10.9 inHg
    VAC = 29.9 - 10.9 = 19 inHg which matches your vacuum gauge reading.
    So reading that I'd say my MAP is correct and I have no vac leak lol. Also i tested with starter fluid in the usual areas, no idle change. Also should mention I'm running 93 octane and have tried sunoco, shell, and citgo all with same results, still stumped. Luckily it is still under warranty so if I can't pinpoint it with your guys help they can figure it out haha
  7. #7 Re: Chasing P0300
    Apr 2011
    South Dakota
    Seems like that vacuum pressure might be low. Normal is 20" or so. I would be tempted to say chase a vacuum leak but your fuel trims are normal.
    I love Decker<3
  8. #8 Re: Chasing P0300
    Apr 2011
    South Dakota
    Possibly but it also be acting like that due to the missfire. Most of the time you'll have a major power loss with a bad cat
    I love Decker<3
  9. #9 Re: Chasing P0300
    Apr 2011
    Sicklerville, NJ
    Chalk it up to a clogging catalytic converter. Thanks for the help everyone in narrowing this issue down. She runs so much better with being able to exhale. By the wat the misfires were all on the rear cylinders, that's what made us pull the cat and crap just fell out of it all over the shop floor lol
  10. #10 Re: Chasing P0300
    Aug 2012
    Stonington, CT
    Thanks for the follow up...as I was reading down the thread when
    I saw what your downstream o2 was reading I thought bad cat. New cats are beautiful things! Could you notice a big difference in power with the new cat? Did not see you mention lack of power earlier only misfire codes.
  11. #11 Re: Chasing P0300
    Apr 2011
    Sicklerville, NJ
    Never noticed a lack of power since I have only owned the car for 3 weeks. And yes it runs smoother, cooler, more responsive and gained 1.5mpg. It's just a universal cat for now that my buddy had laying around in the shop. Once I put headers on Ill either run no cat or a Magnaflow High Flow cat since thats what I always used on my F-bodies. Now All I am waiting for is the trans to get rebuilt and Ill be in business. Warranty has that covered though Dealership is even covering the cost for upgrades to tougher parts and a shift kit
  1. Chasing Idle Bounce!!
    By robrileyw in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2014, 08:01 PM
  2. Chasing a p0171
    By hensleya1 in forum General Grand Prix Discussion
    Last Post: 06-24-2013, 04:40 PM
  3. Chasing stupid ABS light
    By FordMan77 in forum General Tech Discussion
    Last Post: 09-22-2012, 01:00 AM
  4. Chasing P0171 again
    By GTP in RTP in forum General Tech Discussion
    Last Post: 11-14-2011, 08:00 AM
  5. ltft chasing
    By shawnrandolph in forum PCM Tuning
    Last Post: 08-31-2011, 10:53 AM
