Thread: Dog Bone bushings
Results 1 to 20 of 21
  1. #1 Dog Bone bushings
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Are Poly bushing worth the upgrade?
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Dog Bone bushings
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I am wondering this as well... bump!
  3. #3 Re: Dog Bone bushings
    The Boss Iceman6669's Avatar
    Jun 2011
    Yes.
    2011 F-150 Yote powered
  4. #4 Re: Dog Bone bushings
    Jan 2009
    ny
    I hear the vibration felt through the steering wheel is really annoying and some don't recommend them for a daily driver.
  5. #5 Re: Dog Bone bushings
    Enfield, CT
    I have them and I like them but I will admit some times during stop and go traffic they get annoying but there is a fix, TURN UP THE RADIO lol
  6. #6 Re: Dog Bone bushings
    Jan 2009
    ny
    Quote Originally Posted by HighOctaneRacing View Post
    In what locations do you have the poly's?
    Sent from my SGH-M919 using Tapatalk
  7. #7 Re: Dog Bone bushings
    Poly squares, stock for the Dogbones, and stock good condition motor mounts.. Done
    04 Comp G.
  8. #8 Re: Dog Bone bushings
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    Just do like REDCOMPG said, poly squares, stock for the dog bones and stock motor mounts
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  9. #9 Re: Dog Bone bushings
    Jan 2009
    ny
    I'll give it a try, will probably order ZOO'S poly squares.
  10. #10 Re: Dog Bone bushings
    Quote Originally Posted by kissmyss View Post
    If you mean ZZP... No
    Get intenses one piece instead much better.. I had ZZP before and always got a annoying as clunk anytime the car shifted gears... Bought intenses... Issue disappered
    04 Comp G.
  11. #11 Re: Dog Bone bushings
    Jan 2009
    ny
    Thanks for the advice
  12. #12 Re: Dog Bone bushings
    Jan 2009
    ny
    Spell check, lol. Ok, thanks for the advice.
  13. #13 Re: Dog Bone bushings
    Arizona
    I've had the Intense ones since 09" no cracking or splitting.
  14. #14 Re: Dog Bone bushings
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I just put poly dogbones in and I like them. There's only a slight difference in performance if you ask me. There is vibration but it's not bad. At least doesn't bother me one bit.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  15. #15 Re: Dog Bone bushings
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Mine only viberates when it's cold and idling and it's barely even noticeable worth the money imo I have both circles and squares
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  16. #16 Re: Dog Bone bushings
    Dec 2010
    ATL,Georgia
    Shiiiiiiiit..I've got round and square poly dogbones, poly engine mount, poly trans mount, poly sway bar bushings, and poly LCA bushings... ask me how my vibration is lol.......... don't even notice it any more lol that just power you feel hahaha
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  17. #17 Re: Dog Bone bushings
    Jan 2009
    ny
    Gonna just put the squares in for now and see how that goes. I like a smooth quite car unless I'm getting on it, got a truck to drive when I want loud and rough.
  18. #18 Re: Dog Bone bushings
    Jan 2009
    ny
    I installed the bushings, there's a slight vibration until the car warms up. Once warm, the vibration is gone while idling in park or in gear. The engine used to move a little even with the stock bushing flipped and now there's no movement at all. One of the stock bushings was in decent condition, the other was damaged. Here's some pics;
  19. #19 Re: Dog Bone bushings
    Jan 2009
    ny
    Finished up a few other things, will be taking a nice drive to test things out.
  20. #20 Re: Dog Bone bushings
    Jan 2009
    ny
    Drove around all day today and didn't notice any vibration.
  1. Dog bone flip?
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2012, 08:03 PM
  2. need LCA's/bushings but want poly bushings...
    By Regalgs98 in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2011, 09:24 PM
  3. Dog-Bone flip
    By gahris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2009, 02:16 PM
  4. Bad to the bone
    By silverstreak in forum Off Topic Discussion
    Last Post: 08-25-2009, 05:37 PM
