Thread: Removing A/C condensor without removing radiator?
Results 1 to 9 of 9
  1. #1 Removing A/C condensor without removing radiator?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Can this be done? Specifically, can the condensor be removed through the front by the bumper instead of coming up through the engine bay?
  2. #2 Re: Removing A/C condensor without removing radiator?
    Never Never Land
    I'm gonna say no. I've done a radiator and I don't see any way possible for it to come out of the front with the radiator still there. It's really not bad pulling the radiator out.
  3. #3 Re: Removing A/C condensor without removing radiator?
    Jul 2010
    Coquitlam,BC,Canada
    I'd say pull the rad. Even without the front bumper cover, there isn't much room.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Removing A/C condensor without removing radiator?
    Never Never Land
    Yea. Exactly. There's no room. I don't think the condenser can physically fit through the little cage it's in. Even if it could there's still all kinds of plastic in the way. It takes like an hour to pull the radiator. Drain the coolant. Pull the hoses off. Pull the dog bones and brackets off. Pull the fans out. Couple brackets that secure the radiator. I think it helps pulling those side braces off too IIRC.
  5. #5 Re: Removing A/C condensor without removing radiator?
    Unless you cut it into pieces, there is no way.
  6. #6 Re: Removing A/C condensor without removing radiator?
    hangover park IL
    remove the rad fans and you can lay/set the radiator towards the motor and the condenser will slide straight up between the rad and core support.
    I used to do it all the time without losing a drop of coolant
    ~James~ Psychotic Gearhead
  7. #7 Re: Removing A/C condensor without removing radiator?
    Mar 2014
    Cincinnati, OH
    Nice!! That's good to hear. Was hoping to do it without removing the radiator completely if I didn't have to.
  8. #8 Re: Removing A/C condensor without removing radiator?
    If that's all you wanted to do.. why didn't you ask that question...lol
  9. #9 Re: Removing A/C condensor without removing radiator?
    Mar 2014
    Cincinnati, OH
    Haha, didn't realize it at the time, but that should've been the question to ask.
  1. Replies: 0
    Last Post: 03-15-2014, 03:22 PM
  2. Removing bbv.
    By Bluemagic in forum General Tech Discussion
    Last Post: 06-04-2012, 08:23 AM
  3. How should i go about removing this?
    By IBurnCamaros in forum Detailing Tips and Tricks
    Last Post: 04-27-2011, 10:49 PM
  4. Removing egg smell
    By hanback in forum Visual/Body Modifications
    Last Post: 10-30-2010, 10:23 PM
  5. Removing Oil Pan
    By dhoeschen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 04:27 PM
