Thread: wheel spacer question
Results 1 to 5 of 5
  1. #1 wheel spacer question
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Hi guys I have never used wheel spacers and wondering what size to get?
    its an 04 gtp and my summer setup is 20" msrs with 245/35/20 tires i believe. I don't know the hub bore of the rims but I do know that I didn't need to use hub centric rings when they were installed. They are also 5x114.3 pattern.
    My question is how big can I go on the spacers ( i seem to have a ton of room on the lugs when I tighten them no spacers) and what size hub? Also should the spacers be 5x115 or 5x114.3 with my rim setup?
    thanks
  2. #2 Re: wheel spacer question
    More info on the rims.
    20x???
    Offset??
    You might only get a few MM if you are really close to rubbing, then more fender rolling would be needed.
  3. #3 Re: wheel spacer question
    May 2011
    Ontario
    20x???
    Offset??
    rims are 20.7.5 +35 offset i think
    I bet i could get away with 8 mm spacers all around with no problem but that seems pointless just for 8mm on each side
  4. #4 Re: wheel spacer question
    you'd need longer studs with anything over 10mm and a lot of people just do it to be safe at anything over 5mm spacers.
    i wouldn't even bother with spacers. if you want a lower offset/wider wheel then order a set..
  5. #5 Re: wheel spacer question
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    7.5 is gonna look kinda skinny for a 20" wheel especially when its spaced out more. But its hard to tell how many threads you have left. I thought I had plenty of space for a 10mm but when I actually got them on i couldn't even get the nut past 1 or 2 turns. And longer studs were a pain to change out, I had to take the whole rear hub assembly off and for my car it was rusted on pretty good
  1. are wheel spacer good or bad?
    By 03limitedgtp in forum Tires & Wheels
    Last Post: 02-24-2013, 04:38 PM
  2. Thickest wheel spacer
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 06-13-2012, 12:42 AM
  3. Wheel spacer help
    By cbolts gtp in forum Tires & Wheels
    Last Post: 05-07-2012, 08:54 AM
  4. 2006 GXP Wheel Spacer
    By jsal924 in forum Introductions/Noob Questions
    Last Post: 06-12-2011, 10:20 PM
  5. ZZP S/C Spacer Question
    By SloEvil in forum General Tech Discussion
    Last Post: 07-14-2009, 04:56 PM
