Thread: Front end clunk/click.
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Front end clunk/click.
    Iowa
    Update. LCA's and steering shaaft replace. No more clunk and no more click. Alignment in the morning and shell be good to go. Somepoint over the summer ill need to do the oil pan gasket tho.
  2. #22 Re: Front end clunk/click.
    Jun 2014
    las vegas
    #2 you feel this clicking only when you first start the car and drive off? if so it normal.[/QUOTE]
    Yes I have the clicking coming from the drivers side only when first taking off? Why is this normal and what is it? Thanx for any response. I have a 97 GTP with 40,000 miles (original)
  3. #23 Re: Front end clunk/click.
    Quote Originally Posted by darryl5 View Post
    Yes I have the clicking coming from the drivers side only when first taking off? Why is this normal and what is it? Thanx for any response. I have a 97 GTP with 40,000 miles (original)[/QUOTE]
    its the abs self test, all w bodys with abs do it. it will self test in reverse or forward after you start the car and drive off. its like a crunch sound. if you ride the brake pedal you can feel it sometimes too. or if you hit the brakes when its does the test.
  4. #24 Re: Front end clunk/click.
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by silvermistgt2002 View Post
    How tough was the steering shaft replacement? Did you follow one of the walk throughs on here or did you find another source for procedure? Thanks,
  1. Replies: 26
    Last Post: 07-27-2012, 11:13 AM
  2. 2004 Grand Prix Front End Clunk - TSBs?
    By Overkill in forum General Tech Discussion
    Last Post: 04-27-2012, 03:08 PM
  3. Front End Clunk
    By jcgre3n in forum General Tech Discussion
    Last Post: 03-29-2012, 05:41 PM
  4. 01' GTP Front End Clunk
    By Comanche1959 in forum Brakes/Suspension/Chassis
    Last Post: 02-27-2012, 01:55 PM
  5. Front-End Clunk
    By xerxescct in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2010, 02:25 PM
