Thread: Trans Output Seal Leak
Results 1 to 3 of 3
  1. #1 Trans Output Seal Leak
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Replaced the half shaft a few months back and didn't replace the seal. Its dripping trans fluid from the output seal Is there any tips on replacing the seal (Passenger side) I couldn't find any write ups. It seems pretty straight forward but I thought Id ask first.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Trans Output Seal Leak
    Mar 2012
    NC
    Remove axle...remove old seal...clean area....install new seal using old seal as a driver...lube axle...install axle. Done.
  3. #3 Re: Trans Output Seal Leak
    Nebraska
    Thanks it was pretty simple. I used a 2" pipe fitting to punch it in evenly. I noticed my newish half shaft that goes into the differential has a small amount of play horizontally and vertically is this normal?
  1. Transaxel output shaft bearing and seal replacment
    By rvnwlf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-15-2013, 11:18 PM
  2. 04 W-body trans question, output shaft
    By W30post in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2012, 08:51 AM
  3. Transaxel output shaft bearing and seal question
    By Tony48 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-24-2011, 01:13 PM
  4. Front Crank seal Leak!
    By Soeasytobefake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 11:39 PM
  5. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
