Thread: Replacing Upper Motor Mounts : Help!
Results 1 to 13 of 13
  1. #1 Replacing Upper Motor Mounts : Help!
    GT Level Member Pokealong1227's Avatar
    Oct 2012
    Oak Grove, MO
    So I'm trying to replace the square upper motor mounts on my series II 3800. And let me just say, they're a *****. I've tried twisting, hammering, WD40, cutting, everything and they just won't come out. They refuse to move an inch. They are starting to degrade from what I can only assume is age(11 years 190k miles) and weather(car was kept outside for 10 years). Planning to replace them with some poly motor mounts that I already have and getting those in wont be too big of a problem. But getting these out? It's ridiculous. Any advice on people who have removed them before?
  2. #2 Re: Replacing Upper Motor Mounts : Help!
    what i did was to put the bolt back through it, then used a box wrench smaller then the nut on the bolt, put the nut on, now the wrench is a bolted on pry bar, i pried on it, and used a screw driver to pull the middle lip out of its grove. once this lump in the middle is out of its grove it comes right out.
  3. #3 Re: Replacing Upper Motor Mounts : Help!
    Oct 2012
    Oak Grove, MO
    Not a bad idea prying it out like that. May try that tomorrow. I have tried multiple twisting and pushing methods to try and get them out and it didn't do anything but prying may work better.
  4. #4 Re: Replacing Upper Motor Mounts : Help!
    they do suck to get out, if that fails ya remove the whole mount, and do it in a vice.
  5. #5 Re: Replacing Upper Motor Mounts : Help!
    I used a sawzall. Took about 30 seconds.
  6. #6 Re: Replacing Upper Motor Mounts : Help!
    Oct 2012
    Oak Grove, MO
    Might be a good alternative if I can't pry it out.
  7. #7 Re: Replacing Upper Motor Mounts : Help!
    Oct 2012
    Oak Grove, MO
    Prying worked great. Got the old ones out. Do either of you have the intense mounts? They look like they're gonna be a snug fit so I'm just wondering which way the lipped corner of the mount is supposed to face.
  8. #8 Re: Replacing Upper Motor Mounts : Help!
    Oct 2012
    Oak Grove, MO
    Figured it out. Longer lip facing engine, shorter lip facing down. Popped right in. Other than a WAI and exhaust, the poly mounts are hands down the most noticeable mechanical mod I have done. Much better feel when driving, can tell the power is being sent to the wheels much better/quicker, shifts aren't as jarring yet still stiff, and the engine doesn't shake around nearly as much making for a much more enjoyable ride. Feels more powerful and meaner, yet much more comfortable. Great upgrade for a great price and in reality not too much work.
  9. #9 Re: Replacing Upper Motor Mounts : Help!
    I have 3800 performance poly's
  10. #10 Re: Replacing Upper Motor Mounts : Help!
    Oct 2012
    Oak Grove, MO
    I heard those are good. Pretty similar to Intense's. From what I've heard all of the one piece poly's are pretty good.
  11. #11 Re: Replacing Upper Motor Mounts : Help!
    Florida
    i used a serated knife,took about 2min each.
  12. #12 Re: Replacing Upper Motor Mounts : Help!
    Cutting bit + dremel = easy peazy
    04 Comp G.
  13. #13 Re: Replacing Upper Motor Mounts : Help!
    Oct 2012
    Oak Grove, MO
    Using scotty's prying method I got each one out in about a minute. Actual effort only took about 10-15 seconds. And that must be one nice knife.
  1. Upper motor mounts
    By luckytii7 in forum Wanted To Buy - Parts
    Last Post: 08-19-2013, 07:16 PM
  2. Installing upper poly motor mounts?
    By Smokin2000gtp in forum General Tech Discussion
    Last Post: 10-12-2010, 11:10 PM
