Thread: Oil pressure monitoring
Results 1 to 20 of 29
  1. #1 Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    Something has been disconnected on Halfassery that is causing my AeroForce to have a false oil pressure (none actually) reading.
    Since the level sensor has been removed from the pan, I'd like to get this fixed in case of a leak or something.
    thoughts?
  2. #2 Re: Oil pressure monitoring
    thats the low oil sensor. and why is it missing? that one is in the front of the oil pan, bumper side of the car.
    the pressure sensor is in the oil filter housing.
  3. #3 Re: Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    Dude removed it to install a line that returns oil from the turbo.....Looks like CRAP too.
  4. #4 Re: Oil pressure monitoring
    nothing like making a new hole and using a fitting to seal it off ehh?
    check if the oil pressure sensor is plugged in. if you have a oil pressure gauge already it maybe unhooked.
  5. #5 Re: Oil pressure monitoring
    Aeroforce can't read oil pressure.
    Unless they have a special harness and add on for a oil pressure gauge. The factory pressure gauge on the oil filter housing is just a dummy sensor to let you know the motor is dead.
  6. #6 Re: Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    Oh brother.......So, I have no way of Knowing if the oil gets low........WONDERFUL........ "HALFASSERY" is THE perfect name!
    BTW, I do not have a factory oil pressure gauge......
  7. #7 Re: Oil pressure monitoring
    It's just how the 3800 is, as with tons of other motors. The oil light on the dash is just there to warn you of low oil pressure and that something is wrong, and in the end the motor is likely toast.
  8. #8 Re: Oil pressure monitoring
    Quote Originally Posted by traildog View Post
    add a oil pressure gauge, get one thats 2 in one, like volts or something. takes up less room in the pod, if theres any left, if not, dash pod time.
    me i have no clue at all. i took the low pressure sensor out and plugged the hole with a brass plug. i blew 3 of them up, wasn't going for a 4 th.
  9. #9 Re: Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    I wonder if I can change the oil pan......and how difficult it is............
  10. #10 Re: Oil pressure monitoring
    oil pan is no fun to get off when in the car, doable, but no fun.
  11. #11 Re: Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    Well crap......
  12. #12 Re: Oil pressure monitoring
    that sensor is not really needed, just check your oil often. the one in the front just tells you its low.
    the pressure sensor that sob dont turn on unless its down to 5 psi or less, and its way to late by then.
  13. #13 Re: Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    I kinda wondered about that.....It's mounted awfully low in the pan. By the time it gets that low, it's all over...............
  14. #14 Re: Oil pressure monitoring
    Nov 2013
    Wisconsin!
    Why not just be diligent in checking the oil once a week? If you have to rely on sensors for stuff like that, it will be too late to save it.
  15. #15 Re: Oil pressure monitoring
    Dec 2012
    Where 4T65E's were born
    ^ That's the point of the low oil level light, to warn you before it's too late. The low oil pressure switch light means it's too late.
    The low oi level sensor is a nice thing to have, the engine can keep oil pressure with like 2 quarts of oil minimum and it will warn you if you're down to like 3.5 quarts. Plenty of cars with no low oil sensor blow up because it was sucking air and eventually dies, apparently not enough to trigger the low oil pressure light, which is like they said, a dummy light meaning the engine's toast. Checking the oil often won't always ensure you either, if the oil pressure switch blows out it dumps oil, and fast. So that's why I like it.
    Sold.
  16. #16 Re: Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    Quote Originally Posted by koRnhead View Post
    Uh......I check it everyday...........I don't trust this ride yet..........
  17. #17 Re: Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    That's why I'm looking for some type of warning indicator..........
  18. #18 Re: Oil pressure monitoring
    install a pressure gauge. you'll know when its a quart low just by looking at the gauge.
  19. #19 Re: Oil pressure monitoring
    Banned
    Dec 2013
    Indiana
    Looking into that right now ..........
  20. #20 Re: Oil pressure monitoring
    a whole list of em for ya. http://www.ebay.com/bhp/electric-oil-pressure-gauge
    make sure they one you get is not mechanical, you dont want a oil filled tube running into the car.
  1. Computer monitoring?
    By chris99gtp in forum General Tech Discussion
    Last Post: 07-14-2014, 10:55 PM
  2. question about tire monitoring system
    By DirtDog in forum Tires & Wheels
    Last Post: 01-06-2013, 09:37 PM
  3. How to reset tire pressure monitoring system?
    By gpcruzin in forum Tires & Wheels
    Last Post: 12-07-2011, 12:06 PM
  4. tire pressure monitoring system light
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-02-2008, 09:13 PM
  5. Monitoring IC temps
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 09:28 PM
