Thread: Ok to drive without supercharger working?
Results 1 to 16 of 16
  1. #1 Ok to drive without supercharger working?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Quick question for a little reassurance. My tensioner pulley seized and threw my belt for the supercharger.....its basically just an UIM right? I should be ok driving without it?
  2. #2 Re: Ok to drive without supercharger working?
    Mar 2012
    NC
    Yeah...it'll just be slooooooowwwwwwww.
  3. #3 Re: Ok to drive without supercharger working?
    you can, it will just feel gut less. the sc pulley will spin, thats ok, let it.
  4. #4 Re: Ok to drive without supercharger working?
    Mercer, Pa
    Make sure you let the supercharger spin freely or it won't just be gutless it will have problems getting up to 55mph.
  5. #5 Re: Ok to drive without supercharger working?
    Nov 2010
    Illinois
    Yeah its def a lot slower. I've noticed lol and its free I removed all the pieces of the belt. Anyone know if the tensioner pulley can be replaced or do I have to get the whole assembly?
  6. #6 Re: Ok to drive without supercharger working?
    pulley can be changed. i just did mine a few weeks ago. it was chirping when cold for months, i finally thought,,hmmmmm i should change that before it takes the belt out. after the belt was off the pulley barely spun. new was like 20 bucks for a dayco at advance auto.
    mine was normal threads too for the pulley bolt.
  7. #7 Re: Ok to drive without supercharger working?
    Just don't mash it, there will be no extra air for all that fuel that gets dumped in when in boost.
  8. #8 Re: Ok to drive without supercharger working?
    I don't really care for the Dayco pulleys, all the ones I have purchased started chirping after a few months of use.
  9. #9 Re: Ok to drive without supercharger working?
    ill keep that in mind. see how it goes over the next few months i guess.
  10. #10 Re: Ok to drive without supercharger working?
    Mercer, Pa
    Mexpulley on eBay uses brand name bearing, NTN and metal pulleys.
  11. #11 Re: Ok to drive without supercharger working?
    i wonder if you could just replace the bearing. looks like it would press right out/in.
  12. #12 Re: Ok to drive without supercharger working?
    Mercer, Pa
    Metal pullies you can but bearing cost you about $10
  13. #13 Re: Ok to drive without supercharger working?
    Smooth metal pulleys can get bearings replaced, done it at work before.
  14. #14 Re: Ok to drive without supercharger working?
    Nov 2010
    Illinois
    So u guys recommend me just changing the pulley? If so what should I get
  15. #15 Re: Ok to drive without supercharger working?
    not a dayco it seems lol
  16. #16 Re: Ok to drive without supercharger working?
    SE Level Member Jake U's Avatar
    Apr 2013
    Waukesha, WI
    I think I will be replacing mine this weekend mine is chirping like crazy!
  1. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  2. Need help on removing supercharger nose drive
    By jakegee01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2012, 03:30 AM
  3. Drive without supercharger belt?
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2011, 01:04 PM
  4. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  5. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
