Thread: Intense tuning question
Results 1 to 2 of 2
  1. #1 Intense tuning question
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    I was gonna order a intense tune and I was looking over the option and it listed this:
    Increase WOT shift points to approximately 6,000 RPM and engine rev limiters to 6,200 RPM - ideal for vehicles with higher ratio rocker arms and stock camshaft.
    does my car have to have higher ratio rockers? Will it hurt anything? I was planning on eventually upgrading higher ratio rockers. Will I have to leave the shift points stock till then? Also it has this option:
    Increase WOT ignition timing tables by up to 1 degree - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (+$20.00)
    All of the premium around here is 93 octane so would this be a good option? My car is bone stock at the moment but I eventually plan on running cai, 1.9 rockers, 3.5 pulley, and 3inch catless downpipe.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Intense tuning question
    Don't change the shift point with stock valve train, you don't make any power past 5400-5500 anyway.
    Even if you upgraded to 1.9's, a tune isnt even needed.
    I'd leave the wot timing stock, and keep running 93 octane. Would be somewhat wise to have a way to scan the car before dropping pulleys.
  1. Tuning question
    By Impalass in forum General Tech Discussion
    Last Post: 04-07-2012, 01:08 AM
  2. Tuning question
    By Impalass in forum Shops and Community Heroes
    Last Post: 04-04-2012, 10:29 PM
  3. Intense S1x cam centerline -- other question
    By LapeerGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2012, 09:07 PM
  4. Tuning question
    By xsvtank in forum General Tech Discussion
    Last Post: 07-29-2010, 08:14 AM
  5. Intense MPS Hub Question??
    By Uno99 in forum General Tech Discussion
    Last Post: 10-19-2009, 09:46 PM
