Thread: GXP clunk from park to drive, drive to reverse..
Results 1 to 6 of 6
sasquatch094 GXP clunk from park to drive,... 08-12-2013, 03:30 PM
sasquatch094 Re: GXP clunk from park to... 08-12-2013, 03:39 PM
Scottydoggs Re: GXP clunk from park to... 08-12-2013, 03:41 PM
02NavyBlue Re: GXP clunk from park to... 08-12-2013, 03:51 PM
chburnham Re: GXP clunk from park to... 02-13-2014, 03:47 PM
sasquatch094 Re: GXP clunk from park to... 02-13-2014, 04:27 PM
  1. #1 GXP clunk from park to drive, drive to reverse..
    GT Level Member sasquatch094's Avatar
    cleveland
    need some help on this problem i have with my 08 grand prix. From park to drive or drive to reverse my car lets out a nice clunk/knock sound. I had someone look at the motor mounts while shifting the car and didnt appear to be the sound. I had them then look at the cv axle and seems like its coming straight from that. Almost as if the cv axle spins a hair before the wheel bearing moves then the sound occurs.
    The cv axle has quite a bit of movement near the transmission(passenger side btw). Both the axle and wheel bearing has been replaced within the last 3 months. the noise started basically right after i replaced those parts. Faulty cv axle? surtrack gm-8226 is the part number...
    Thanks
  2. #2 Re: GXP clunk from park to drive, drive to reverse..
    cleveland
    Amazon.com: ACDelco 15850525 Front Wheel Drive Shaft Assembly: Automotive
    seem right? should i got with an ACdelco or buy another aftermarket? a1cardone? epmi?
  3. #3 Re: GXP clunk from park to drive, drive to reverse..
    pop the hood, then shift it from P to R then to D, if the motor is bouncing a lot when shifting, its the lower mounts. you can also flip the dog bone mounts to help firm the engine up.
    if the mounts are real bad the engine will twist in the engine bay when shifted from R to D or the other way round.
  4. #4 Re: GXP clunk from park to drive, drive to reverse..
    Dec 2012
    Where 4T65E's were born
    Well since it seems like the cv axle, can you exchange the part for another one?
    Sold.
  5. #5 Re: GXP clunk from park to drive, drive to reverse..
    Feb 2014
    United States
    Did you replace them yourself? My gtp i replaced the wheel bearings and for some reason the bolts backed themselves out a little bit and was allowing the bearing to shift itself this also allowed it to slightly pull the cv joint apart. Just some ideas.
  6. #6 Re: GXP clunk from park to drive, drive to reverse..
    cleveland
    sorry i never updated this thread. But i noticed movement in the upper dogbone, so i replaced it with a Poly. The lower mounts were okay, but it was the CV axle again. After the second replacement of the same brand (warranty covered the second replacement) i went to an A1 cardone axle and have been fine since.
    Dont buy surtrack lol
  1. Car will only drive in reverse..
    By Akcalvinkid in forum General Tech Discussion
    Last Post: 06-02-2013, 02:25 AM
  2. Car stalls when shifting from Reverse to Drive
    By gamefreak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2013, 08:52 PM
  3. 01 GTP Goes nowhere in drive Slips in 1,2,3 and Reverse
    By TheMadTitian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2012, 05:59 PM
  4. old people CANNOT drive/park
    By sLpGPGT in forum Off Topic Discussion
    Last Post: 02-11-2012, 05:53 PM
  5. Shift from park to reverse or drive, quick question
    By calvin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2011, 04:20 PM
