Thread: Throwing codes
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 99
  1. #1 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Quote Originally Posted by GTP89 View Post
    So what did you do to make the others dissapear lol
    Heck I don't know......................
  2. #2 Re: Throwing codes
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    What year is the car again?
  3. #3 Re: Throwing codes
    http://www.gmforum.com/2000-2005-90/...-p1133-289833/ good post on the p1133 code. try plugging in the upper o2, maybe its not deleted? that code leads to it.
    http://www.carobdcodes.com/pontiac-p...e-bank-2.shtml the p1563 looks to be the rear o2 acting up. maybe bad.
    and the last one is a wastegate code, dont know what to tell ya on that one being its turbo.
  4. #4 Re: Throwing codes
    Dec 2011
    Ontario,Canada
    The main Bank 1 narrow band 02 is not deleted Scotty, only thing different is the location. I'ts in the upper downpipe behind the turbo now, confusing part is the old Bank one narrow band o2 was left in the stock location in the rear manifold when the turbo swap was done. Looks to me from the code either the main o2 is bad or still unplugged?
    The one other code was a P1653(Oil Level Lamp Control Circuit) not a P1563
    The P0243 is for the missing s/c boost bypass that he dosen't have/need anymore.
  5. #5 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Po243.......Excellent!
    P1653......The plug for the oil level sensor is hanging by the pan, and the sensor is gone, so, I'm guessing THAT's the problem.......
    P1133......I'll be trying a new o2 sensor next week.......Thanks! Video (a world premier) is on the way.......
  6. #6 Re: Throwing codes
    im a learning still about the turbo set ups.
    im good at switching a nunber around here and there too lol
  7. #7 Re: Throwing codes
    Dec 2011
    Ontario,Canada
    I'm still learning about...everything even at my old age LOL
    Went through the same process with mine when I got it!
    Why is this unplugged, why is the IAT dangling in the engine bay and so on and so on LOL
  8. #8 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    And now......the World Premier.........
  9. #9 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    you didn't switch the plug/cylinder numbers did you? BWAAAAAAAAAA!!
  10. #10 Re: Throwing codes
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Damn those are the codes I am trying to get rid off
    If You Cant Hear The Whine You're Too Far Behind...
  11. #11 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    installing a new o2 sensor tomorrow. I'll let you know if that works.
  12. #12 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Oops. You meant the ones that disappeared. I changed plugs and wires.
  13. #13 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Well, the new o2 sensor didn't solve it. Do these turbo cars have a PCV?
  14. #14 Re: Throwing codes
    Dec 2011
    Ontario,Canada
    No PCV, hence the breather on the valve cover.
  15. #15 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Hey, thanks. the hose on that breather came off while my son was driving it...must have run pretty bad....another bad plumbing job now fixed.
  16. #16 Re: Throwing codes
    Don't worry about the code 1133, it's a very common code when people install headers.
    In your case it's a turbo, but pretty much the same thing.
    I had the code for a month or so and then it just stopped showing up, it never would trip the SES light either, just in the pending history codes.
  17. #17 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    I wonder why it only misfires when it's idling?
  18. #18 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Thanks. I'm still chasing the misfire problem.....I'm looking at the coil packs next. Still need to clean up the connections to see if that helps.
  19. #19 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Can vacuum leaks cause misfire?
  20. #20 Re: Throwing codes
    Mercer, Pa
    Vacuum leaks cause most misfires!
  1. Replies: 5
    Last Post: 02-02-2013, 07:03 PM
  2. Just throwing this out there
    By DirtDog in forum Off Topic Discussion
    Last Post: 12-21-2012, 06:43 PM
  3. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  4. Changed o2 sensor and Still throwing out same codes!?????
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2011, 04:16 PM
  5. Throwing codes
    By batman1988 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2011, 03:37 PM
