I went to autozone a while ago and ran the codes on the car. I got "bank 1 to lean" and "cylinder 3 misfire". I checked my o2 extension wires and my buddie wired up the 2 brown wires wrong. I fixed those and the cyl 3 misfire went away. I am still getting bank 1 to lean. I have had all the injectors flow matched and even changed the plugs. It is still throwing the code. Before my gas milage was really bad, i went 200 mi before i had to fill up. Now i am at 168mi and still have 5/8 a tank left. So today i went to autozone and grabbed there scanner and this is what i got. I dont know if this will help out any or not. All i can say is HOLY TIMING ADVANCE BATMAN!
TPS(%) 0.0-0.4
RPM 780-822
CALC LOAD(%) 2.0
MAF(LB/M) 0.00
MAP("HG) 10.0
COOLANT 180 DEG
IAT 133 DEG
IGN ADV (DEG) 20.5-22.0
ST FTRM1 3.9%
LT FTRM1 -10.9%
FUEL SYST 1 CLSD
FUEL SYST 2 N/A
o2S11(V) 0.030-0.900
ST FTRM11 -1.6
o2 S12(V) 0.450
That is what the scanner showed. So is my 3800 performance PCM causing bank 1 to run to lean?
