Thread: Throwing codes
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 99
traildog Throwing codes 02-07-2014, 05:36 PM
GTP89 Re: Throwing codes 02-07-2014, 07:01 PM
rockquarryman Re: Throwing codes 02-07-2014, 07:07 PM
traildog Re: Throwing codes 02-07-2014, 07:02 PM
traildog Re: Throwing codes 02-07-2014, 07:06 PM
traildog Re: Throwing codes 02-07-2014, 07:37 PM
Scottydoggs Re: Throwing codes 02-07-2014, 07:43 PM
GTP89 Re: Throwing codes 02-07-2014, 07:50 PM
traildog Re: Throwing codes 02-07-2014, 07:58 PM
Scottydoggs Re: Throwing codes 02-07-2014, 08:00 PM
GTP89 Re: Throwing codes 02-07-2014, 08:08 PM
traildog Re: Throwing codes 02-07-2014, 08:05 PM
GTP89 Re: Throwing codes 02-07-2014, 08:09 PM
traildog Re: Throwing codes 02-07-2014, 08:15 PM
traildog Re: Throwing codes 02-08-2014, 07:10 AM
Iceman6669 Re: Throwing codes 02-08-2014, 09:54 AM
traildog Re: Throwing codes 02-08-2014, 10:42 AM
traildog Re: Throwing codes 02-08-2014, 07:08 AM
Scottydoggs Re: Throwing codes 02-08-2014, 08:07 AM
traildog Re: Throwing codes 02-08-2014, 08:16 AM
Scottydoggs Re: Throwing codes 02-08-2014, 08:19 AM
traildog Re: Throwing codes 02-08-2014, 06:36 PM
traildog Re: Throwing codes 02-08-2014, 08:26 AM
Scottydoggs Re: Throwing codes 02-08-2014, 09:58 AM
Iceman6669 Re: Throwing codes 02-08-2014, 10:01 AM
Scottydoggs Re: Throwing codes 02-08-2014, 10:12 AM
Iceman6669 Re: Throwing codes 02-08-2014, 10:13 AM
Scottydoggs Re: Throwing codes 02-08-2014, 10:15 AM
Iceman6669 Re: Throwing codes 02-08-2014, 10:16 AM
Scottydoggs Re: Throwing codes 02-08-2014, 10:19 AM
Iceman6669 Re: Throwing codes 02-08-2014, 10:20 AM
Scottydoggs Re: Throwing codes 02-08-2014, 10:21 AM
traildog Re: Throwing codes 02-08-2014, 10:45 AM
Scottydoggs Re: Throwing codes 02-08-2014, 10:47 AM
traildog Re: Throwing codes 02-08-2014, 11:19 AM
Scottydoggs Re: Throwing codes 02-08-2014, 10:46 AM
231FUN Re: Throwing codes 02-08-2014, 11:15 AM
traildog Re: Throwing codes 02-08-2014, 11:24 AM
Scottydoggs Re: Throwing codes 02-08-2014, 11:20 AM
Scottydoggs Re: Throwing codes 02-08-2014, 11:28 AM
Scottydoggs Re: Throwing codes 02-08-2014, 11:43 AM
231FUN Re: Throwing codes 02-08-2014, 11:46 AM
231FUN Re: Throwing codes 02-08-2014, 11:56 AM
traildog Re: Throwing codes 02-08-2014, 11:57 AM
231FUN Re: Throwing codes 02-08-2014, 12:04 PM
Scottydoggs Re: Throwing codes 02-08-2014, 12:02 PM
231FUN Re: Throwing codes 02-08-2014, 12:17 PM
traildog Re: Throwing codes 02-08-2014, 12:27 PM
traildog Re: Throwing codes 02-08-2014, 12:30 PM
traildog Re: Throwing codes 02-08-2014, 12:48 PM
traildog Re: Throwing codes 02-08-2014, 02:08 PM
traildog Re: Throwing codes 02-08-2014, 02:15 PM
traildog Re: Throwing codes 02-08-2014, 12:31 PM
Scottydoggs Re: Throwing codes 02-08-2014, 12:39 PM
231FUN Re: Throwing codes 02-08-2014, 12:42 PM
traildog Re: Throwing codes 02-08-2014, 01:54 PM
231FUN Re: Throwing codes 02-08-2014, 03:21 PM
GTP89 Re: Throwing codes 02-08-2014, 06:59 PM
traildog Re: Throwing codes 02-08-2014, 07:01 PM
231FUN Re: Throwing codes 02-08-2014, 02:14 PM
Scottydoggs Re: Throwing codes 02-08-2014, 02:16 PM
231FUN Re: Throwing codes 02-08-2014, 03:38 PM
traildog Re: Throwing codes 02-08-2014, 03:34 PM
Scottydoggs Re: Throwing codes 02-08-2014, 03:50 PM
231FUN Re: Throwing codes 02-08-2014, 03:58 PM
traildog Re: Throwing codes 02-08-2014, 04:03 PM
traildog Re: Throwing codes 02-08-2014, 04:01 PM
GTP89 Re: Throwing codes 02-08-2014, 09:43 PM
traildog Re: Throwing codes 02-08-2014, 09:58 PM
traildog Re: Throwing codes 02-08-2014, 09:59 PM
traildog Re: Throwing codes 02-09-2014, 10:56 AM
231FUN Re: Throwing codes 02-09-2014, 11:07 AM
traildog Re: Throwing codes 02-09-2014, 11:44 AM
Fivefingerdeathpunch Re: Throwing codes 02-09-2014, 01:36 PM
traildog Re: Throwing codes 02-09-2014, 02:14 PM
traildog Re: Throwing codes 02-09-2014, 02:13 PM
traildog Re: Throwing codes 02-09-2014, 02:28 PM
sseilmnop Re: Throwing codes 02-09-2014, 03:52 PM
sseilmnop Re: Throwing codes 02-09-2014, 03:53 PM
traildog Re: Throwing codes 02-09-2014, 04:48 PM
Scottydoggs Re: Throwing codes 02-09-2014, 04:51 PM
traildog Re: Throwing codes 02-09-2014, 05:19 PM
Scottydoggs Re: Throwing codes 02-09-2014, 05:27 PM
traildog Re: Throwing codes 02-09-2014, 05:56 PM
sseilmnop Re: Throwing codes 02-09-2014, 05:58 PM
231FUN Re: Throwing codes 02-09-2014, 06:05 PM
traildog Re: Throwing codes 02-09-2014, 06:30 PM
traildog Re: Throwing codes 02-09-2014, 06:52 PM
traildog Re: Throwing codes 02-20-2014, 07:00 PM
Sven the Sexman Re: Throwing codes 02-20-2014, 07:01 PM
traildog Re: Throwing codes 02-20-2014, 07:19 PM
Sven the Sexman Re: Throwing codes 02-20-2014, 07:22 PM
traildog Re: Throwing codes 02-20-2014, 07:33 PM
  1. #1 Re: Throwing codes
    funny part is all these codes popped up after the tune up he did.
    that being said, make sure the plugs aren't cracked. if your socket dont have the foam insert they may have cracked on you.
  2. #2 Re: Throwing codes
    short of taking the front of the engine off so you can see the end of the cam. or a degree wheel can tell you. but thats a process all its own.
  3. #3 Re: Throwing codes
    this plug should reach the o2 sensor by the back spark plug
    this o2. its pig tail should reach the plug up top.
  4. #4 Re: Throwing codes
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Pull a valvecover, pull a rocker and put a dial indicator in the end of the pushrod and read the cam lobe lift and compare to know stats for stock cam/aftermarket cam is the easiest. No need to pull timing cover.
    I would start with making sure your coils are cleaned and wires are good and all the wiring that should be plugged in for your car is most importantly the Bank1 O2 sensor that is in upper turbo downpipe.
    I reccomend getting rid of the old o2 sensor in the stock location in the rear manifold and putting a bung plug in it's place... it seems to have confused you and others more than a couple times LOL
  5. #5 Re: Throwing codes
    Dec 2011
    Ontario,Canada
    Turbo setup does NOT use the stock Bank 1 O2 sensor location.
    It is moved to the upper downpipe, that is where the Bank 1 O2 pigtail from the wire harness needs to be plugged in.
    Disregard the O2 sensor that is in the rear manifold and pull it out of there and plug it up so it does not confuse you and other supercharged guys anymore!
  6. #6 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    This plug comes from the o2 sensor in the rear manifold. It was not plugged in. I unplugged the sensor in the DP, and plugged in the one in the rear manifold.
  7. #7 Re: Throwing codes
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by traildog View Post
    WHY?
    That plug needs to go to the O2 sensor in your upper down pipe.
    Like I said, forget that O2 sensor in the rear manifold is even there PULL IT OUT!
  8. #8 Re: Throwing codes
    if they have a crack they can act up when they warm up sometimes, or all the time.
    id listen to 321fun, he seems to know his turbo set ups.
  9. #9 Re: Throwing codes
    Dec 2011
    Ontario,Canada
    You unplugging the 02 sensor in the DP was responsible for the last two codes you got and possibly the missfire code aswell.
    Not sure what made you go back to plugging the o2 pigtail back into the rear manifold location, we've been over that more than a few times now. Pull the damn 02 sensor from that rear manifold and plug it with a bung hole plug before it confuses you again.
    you're confusing yourself and making problems , if your not comfortable with where things are routed yet take pics before you start unhooking wiring so stuff goes back where it's supposed to.
  10. #10 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Quote Originally Posted by 231FUN View Post
    The codes came BEFORE I changed the plugs. I'm plugging back in the o2 sensor on the down pipe and removing the one in the manifold. I can buy a plug to close the hole at my local OReillys.
    I'm going to clean up the coil paks and see if that helps. I found spider eggs under one of them.........EWEWWWWWWW!
  11. #11 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    And quit YELLING at me........
  12. #12 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    I'm not going to try to remove the one in the manifold.......it's to friggin tight in there to get any kind of wrench on it........makes a nice plug too.........
  13. #13 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Looking at ebay prices on new coils.....I'm thinking about giving a set a try......
  14. #14 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
  15. #15 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    Maybe I have a bad o2 sensor? DAMIT!
  16. #16 Re: Throwing codes
    or a burnt wire in the o2 harness. i dont yell at least lol
  17. #17 Re: Throwing codes
    Dec 2011
    Ontario,Canada
    Well ya got two there and one is just plugging a hole...so maybe one is good
  18. #18 Re: Throwing codes
    Banned
    Dec 2013
    Indiana
    So, before my son left for his girlfriend's, I took another code reading. No CE light, just told the scangauge (I love that thing) to read the codes.......
    Stay tuned for a lovely video featuring this gauge reading misfires.......
  19. #19 Re: Throwing codes
    Dec 2011
    Ontario,Canada
    P0243 - Turbocharger Wastegate Solenoid 1 -you don't need to worry about that, boost bypass for s/c is gone
    P1653 - Oil Level Lamp Control Circuit- maybe didn't get connected properly after installing turbo oil feed there?
    P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1- I'd say either the o2 sensor(Bank1) is bad/not plugged in properly or a issue with the pigtail from the wire harness to the o2 sensor
  20. #20 Re: Throwing codes
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    So what did you do to make the others dissapear lol
    If You Cant Hear The Whine You're Too Far Behind...
  1. Replies: 5
    Last Post: 02-02-2013, 07:03 PM
  2. Just throwing this out there
    By DirtDog in forum Off Topic Discussion
    Last Post: 12-21-2012, 06:43 PM
  3. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  4. Changed o2 sensor and Still throwing out same codes!?????
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2011, 04:16 PM
  5. Throwing codes
    By batman1988 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2011, 03:37 PM
