Thread: How about a little wiring help?
Results 1 to 9 of 9
  1. #1 How about a little wiring help?
    Banned
    Dec 2013
    Indiana
    I'm trying to wire the lighting on the gauges and get the AeroForce to power up and down properly.
    I have the "add a circuit" fuse holder to plug into the fuse box, but, I need help figuring out which slot to plug it into.
    What say you gauge wizards?
  2. #2 Re: How about a little wiring help?
    Use the radio fuse or a IGN fuse.
    Make sure if there is a red jump on the back of the aeroforce, it needs to be removed to work with a 12v power source.
  3. #3 Re: How about a little wiring help?
    Banned
    Dec 2013
    Indiana
    Gonna go give it a try right now!
  4. #4 Re: How about a little wiring help?
    Banned
    Dec 2013
    Indiana
    Works like a charm! Thanks FFDP! (I bet that would hurt)
  5. #5 Re: How about a little wiring help?
    Banned
    Dec 2013
    Indiana
    BTW, ALL of the gauges require 12v. Is is ok to use the same fuse for all 3?
  6. #6 Re: How about a little wiring help?
    You really shouldnt use the same one, it could overload the circut.
    I use both the radio fuse and a IGN fuse for my gauges. That way both are on with key on engine off and shut off when I eiter turn the car off or open the door.
  7. #7 Re: How about a little wiring help?
    Banned
    Dec 2013
    Indiana
    Ok. I'll buy another "add a circuit" and separate them. Can't wait till they function properly.
    Thanks for the help.
  8. #8 Re: How about a little wiring help?
    Nov 2011
    NY
    3 gauges will not OL a 10amp fuse... Just sayin!
    One (add-a-circuit) is fine, just make sure you chose a good ground point. The ground bar just by the brake pedal, is a good spot.
  9. #9 Re: How about a little wiring help?
    Banned
    Dec 2013
    Indiana
    Got the boost gauge lit up tonight!. Makes it so much easier to see.........
  1. Need help with wiring
    By Torok in forum Off Topic Discussion
    Last Post: 04-21-2011, 06:59 PM
  2. Amp and sub wiring
    By beerfun in forum Audio, Security & Visual Electronics
    Last Post: 08-24-2010, 01:33 AM
  3. Need help wiring amp
    By jjwitty in forum Introductions/Noob Questions
    Last Post: 07-24-2009, 01:59 PM
  4. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  5. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
