Thread: Does the turbo wastegate pipe need to route under the car?
Results 1 to 20 of 22
  1. #1 Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    I'm trying to eliminate a really annoying rattle when the wastegate pipe and exhaust pipe get together.
    I was thinking about whacking off the pipe, but, that would cause it to dump in the engine compartment.
    The car is running well, but the rattle is ANNOYING.......
  2. #2 Re: Does the turbo wastegate pipe need to route under the car?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Loosen up crossover and down pipe and wg perch then adjust and retighten. I assume you have a Z3 kit by the looks of it.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    Quote Originally Posted by GMR Badass View Post
    I wish I knew WTH I had....trying to learn slowly but surely.
  4. #4 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    Why does it look like one turbo charger is hooked to another?
  5. #5 Re: Does the turbo wastegate pipe need to route under the car?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    It's just one. The rust colored part is the exhaust side and the shiny part is the air intake side.
    I went NA when a whore left -$300 in my bank account.
  6. #6 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    Quote Originally Posted by indygrandprix View Post
    Got ya, Thanks. So, If I loosen the clamp on the exhaust side, I can move the pipe? It appears to be just hanging off of the exhaust side.
  7. #7 Re: Does the turbo wastegate pipe need to route under the car?
    Apr 2011
    Columbus, OH
    What you have is the Z3 kit which has an open waste gate dump tube to atmosphere. I would only mess with the perch that is attached to the rear exhaust manifold which connects to the waste gate and then to the dump tube. With those three connection points you should be able to have enough play to make proper adjustments.
  8. #8 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    Thanks. I'm gonna give it a go in a few.
  9. #9 Re: Does the turbo wastegate pipe need to route under the car?
    Apr 2011
    Columbus, OH
    I'm on my phone or I'd type more. Forget about the crossover and down pipe for now..... just try adjusting the waste gate setup and is that doesn't work then resort to that.
  10. #10 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    So, here's the pipe causing the problem. I've looked at it from all angles and can't see how I could move it to eliminate the rattle.
    Still thinking on it............
  11. #11 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    is it safe to loosen the 2 clamps so I can move the pipe around a bit?
  12. #12 Re: Does the turbo wastegate pipe need to route under the car?
    Apr 2011
    Columbus, OH
    No need to remove the clamps but V-band is very easy to take off and put back on... EDIT: IF you do want to try and adjust lossen the one that's closest to the top...you'll be able to move that pipe towards font/back (bumper to bumper).
    http://shop.zzperformance.com/store/...ate-Perch.aspx
    This piece (it's the piece that the wastegate is sitting on top of) is going to be the one where you ill be able to make the most adjustments with. From the top of the motor it's about impossible to get to it with the WG right in the way. You should be able to get to the 2 bolts from the bottom. Loosen both bolts and push the pipe to one side and tighten back down.
  13. #13 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    Did that. The pipe won't move enough to clear the exhaust union.
    Trying this now. Dam it's tight under there........
  14. #14 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    I give up! The bolts to the perch are so rusted I'm no going to attempt to loosen them. If I had a car lift, maybe.
    Thanks for all of the suggestions. I think the pipe needs to be removed and bent or cut.......
  15. #15 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    I wonder how hot the wastegate pipe gets?
  16. #16 Re: Does the turbo wastegate pipe need to route under the car?
    Nov 2013
    Wisconsin!
    How hot does the exhaust get? That's how hot that pipe can get. You can probably shorten it, but I wouldn't just let it dump in the engine compartment. Or you can have an exhaust shop who knows turbo system's re-route the dump tube into the downpipe.
  17. #17 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    If I could just get it away from the exhaust union. Whack it off just above.......
  18. #18 Re: Does the turbo wastegate pipe need to route under the car?
    Nov 2013
    Wisconsin!
    Yes that should work, based on the pic you have above.
  19. #19 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    That pipe only dumps exhaust when the waste gate opens, correct?
    I don't want to smell exhaust when I'm idling at a stop.
  20. #20 Re: Does the turbo wastegate pipe need to route under the car?
    Banned
    Dec 2013
    Indiana
    Well, I got her whacked off, just above the exhaust union......but not enough to clear the bolt head..........You can see in the pic where it was hitting the union.
  1. wastegate actuator
    By kawasakidrivinghick in forum Wanted To Buy - Parts
    Last Post: 02-19-2013, 05:18 PM
  2. Wastegate prob.
    By 420in713 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2011, 11:51 AM
  3. If i need map again what feeds wastegate
    By rodman in forum Turbo
    Last Post: 07-07-2009, 04:14 AM
  4. Wastegate
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 04-18-2009, 04:31 PM
