Thread: HVAC issue? and radio?
Results 1 to 4 of 4
  1. #1 HVAC issue? and radio?
    Oct 2013
    Toronto
    Dual cliimate control system
    I push the fan to go up when i hit the 6 bar of 7 blower motor runs for about 4-5 second then shuts off. if i leave it in five bar runs normal. Fan will stay off for about 10 seconds and then come back on for the 4-5 seconds then out again till i move it back down to the five bar.
    Noticed now when pushing fan button either up or down both fan little yellow lights come on for up and down at same time.
    Also when when going to 6 bar it shows driver and when the fan cuts it quickley changes to pass(passenger) andthen back to driver.
    Blower Motor...... Resister....or climate control? which one sounds more likey?
    Couple days earlier had the radio bulb that display the clock go out, the clock still shows the LCD time very dim but not bright orange, all another light on the radio work. can this bulb be replaced only or straight for a new radio?
  2. #2 Re: HVAC issue? and radio?
    The issue with the speeds sounds like the resistor, wouldnt hurt the clean the contacts on the actual climate control itself aswell.
    Bulb can be replaced, just to take it all apart and install/solder in a new one I think. There might be a write up on that one somewhere.
  3. #3 Re: HVAC issue? and radio?
    Oct 2013
    Toronto
    thank you sir
  4. #4 Re: HVAC issue? and radio?
    Oct 2013
    Toronto
    Must have the electrical demons cause it's working perfect this morning when I started the car just wonder when it will let go for good
  1. HVAC Issue. Cant switch between any of the vents for heat
    By JohnnyV in forum General Tech Discussion
    Last Post: 12-27-2013, 06:58 PM
  2. HVAC Issue, Stuck on Defrost/Lower Only, Help
    By 98GTPDaytona in forum General Tech Discussion
    Last Post: 06-27-2013, 07:07 PM
  3. HVAC Blower, issue.
    By WolvesSoulZ in forum General Tech Discussion
    Last Post: 12-13-2012, 07:44 PM
  4. HVAC Issue
    By mlasnoski in forum General Tech Discussion
    Last Post: 11-17-2010, 09:53 PM
  5. HVAC Wiring Issue
    By a3gtp in forum General Tech Discussion
    Last Post: 06-22-2010, 12:44 AM
