Tuning a 95 is completely 100% impossible.
You could try using an 2.2 mini AFC and getting lucky adjusting for injectors like we used to do before tuners, and install the map sensor between the throttle and the rotor blades so it doesnt see boost. At the same time you could throw in a bigger maf too.... You are probably going to have alot of timing, like 24 degrees, so get ready to put a 4.8 pulley on it, or a cam.
