Thread: Running e85 on stock fuel system
Results 1 to 20 of 37
  1. #1 Running e85 on stock fuel system
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I read up that it can be done on the stock fuel system and that you just have to swap out the injector o rings with 95 Taurus rings. Obviously a tune would be a must to get the full benefit. Just wondering if this is true and if this is the set that would have to be purchased.
    http://shop.advanceautoparts.com/p/f...chTerm=o+rings
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Running e85 on stock fuel system
    May 2012
    Where winter never ends
    No. No. No. and did I say no?
    E85 requires AT LEAST 42.5# injectors, recommended 60# or 80# depending on power levels. You need a tune and anything below a 3.2/3.0 will require a 200+ (Recommend 300+) lph fuel pump. You also NEED a tune. The car will not run without it on full e85. You can get away with e10 maybe e15, but anything more your trims are going to be so whacked your car wont know what to do. I have been running the stuff for over a year now. Love it, but you need the proper stuff.
    EDIT: I got o-rings from the part store, fel-pro ones... they work fine.
    2000 Regal - Winter Beater
  3. #3 Re: Running e85 on stock fuel system
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    ^^What he said^^ Without a tune you're just throwing away mileage and performance. I've heard of stock 3800's running it 50/50 with 93 octane without a problem, but I wouldn't count on that. Unless you tune for it, and hopefully do some supporting mods, don't do it.
  4. #4 Re: Running e85 on stock fuel system
    Feb 2009
    flintnasty MI
    You can swap 42lb injectors in with the e85 swap and it runs great no tuning.
    I imagine you will struggle with fuel pumps and filters making sure that you dont drop fuel pressure.
    With 33lb stock injectors you can run about e60 on a stock pulley. You will see a very small mileage drop. Its a great money saver and you can mix with 87 octane.
    http://www.grandprixforums.net/threa...e-in-E85-areas
  5. #5 Re: Running e85 on stock fuel system
    May 2012
    I would still recommend tuning. Something about running a completely different fuel on a non-tuned pcm worries me.
  6. #6 Re: Running e85 on stock fuel system
    Eau Claire, WI
    My personal experience with e85 was in a FFV Chevy Silverado. The first issue with e85 in a truck designed for it, is that it takes the computer an entire tank full to change it's tune for e85. I think the manual actually wants you to do it in little stages. With e85, the truck lost both power and mileage. Even with e85 being about 30% cheaper, on a 20 hour trip it ended up costing more $$$ than gas did on that same trip back. I/we never tried any blending, but its a gimmick for pickups.
    But I have totally read about other people just straight up switching, no mods or anything. Some guys love it with some vehicles, and others have almost had to be towed home. We just went through a really harsh winter here in Wisconsin. One of the issues that people ran into was a fear of gas lines freezing up. Around here, non-premium gas has about 10% ethanol in it. Out of fear of gas line freezing, people would add a can of HEAT at every fill up. After a few fill ups, this was drastically changing the ratio of alcohol (a mix of alcohols no less) to gasoline. This isn't a guarantee of failure, it's just a good example to me of why I wouldn't run a high ratio of ethanol in my car.
    With support mods on the other hand, it can take out knock, reduce engine heat, and make more power.
  7. #7 Re: Running e85 on stock fuel system
    Arizona
    The early flex fuel vehicles didn't have accurate ethanol sensors. The factory tunes also don't optimize e85,like it could be.
    If you tune the vehicle with extra timing and take the time to see the actual stoich of the E80-E89,you're getting. You will gain some.
  8. #8 Re: Running e85 on stock fuel system
    Arizona
    All injectors are not the same you don't just plop in bigger injectors without proper data, what about your transients?
  9. #9 Re: Running e85 on stock fuel system
    Nov 2011
    NY
    Quote Originally Posted by K Kraziee View Post
    ummmmmmm, ok!
    Mind if you were to post such references so we may examine it too?
    Ummmmmm, nope!
    Not just to tune to get full benefit... But make it work.
    but really, why not just give it a go and let us know how it all worked out?
    To 'my' knowledge, you'd need to:
    1. upgrade fuel pump wiring at a minimum, or bigger pump
    2. Larger injectors
    3. Larger, finer fuel filter
    4. Tune to adjust increased fuel consumption and afr change due to different fuel used.
    Good Luck & Have Fun out there!
  10. #10 Re: Running e85 on stock fuel system
    Apr 2011
    Vassar, Mi
    In theory going E85 with injectors that are 30% bigger could work on a stock tune. I havent tried it but I have a friend that is experimenting with the idea on his DSM. To see any benefits you would also have to give it more timing or more boost.
    Other than tune and injectors though, I ran my stock pump, lines and wiring down to a 2.7" pulley on E85 before it started leaning out! My 302whp dyno was with the stock pump starting to run out of fuel after 5k rpm. Stock replacement fuel filter and stock replacement O rings no issues in 20k miles too btw
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  11. #11 Re: Running e85 on stock fuel system
    Arizona
    There's really no need to guess. I mean its really easy to find your exact stoich with a small beaker. 10ml of water AMD the rest gas/e85 shake it up watch it settle bam. Poor mans ethanol testor
  12. #12 Re: Running e85 on stock fuel system
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Isn't the tune as simple as adjusting the stoich. reference in the cruise tables, and then changing the PE target AFRs as well for the E85?? Wondering if I could pick up injectors, a stock pump rewire, and tweak as few as 2 or 3 tables in my tune and run full E85 without any issues.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  13. #13 Re: Running e85 on stock fuel system
    Apr 2013
    Milwaukee
    I'm thinking with the different results, I could safely run a 20/80 mix on stock injectors for now until I upgrade to bigger injectors then run more. I wouldn't run full e85 unless I was tuned and had a different fuel system. It just seems like with the mixed results it should be Ok. Is it worth it, idk. But e85 here in Milwaukee is like 2.99 so it's a lot cheaper than 93 at the moment.
    Sent from my PantechP8010 using Tapatalk
  14. #14 Re: Running e85 on stock fuel system
    Apr 2011
    Vassar, Mi
    Quote Originally Posted by 97AutoXVette View Post
    You completely can. I picked up a set of 60's used cheap, bolted them in. No need to change any target AFR's, Stoich for all fuels = Lambda 1 it doesnt matter if its E85 or gasoline the O2 sensor doesnt know the difference. For instance running E85 with a wideband setup for gasoline, when it is showing 14.7 you are actually at E85 stoich of 9.76 or lambda 1 all the way around. The gauge is just converting lambda 1 from the sensor to AFR so you have something relatable to read on the gauge. Your stock narrowband works the same way. AFR is just a way to read stoich for different fuels.
    Either way all I needed to do is change the injector tables from stock to 60's then the 30% for e85. Ran the tank dry with the pump on and a fuel line off then filled with E85. Fired right up with no other changes, no pump, no rewire, no injector o-rings, not even a filter change, only took 20 minutes. After that I set the timing from stock to 22* and dropped from my 3.4" pulley to my 3.1" picked up probably 30 hp.
  15. #15 Re: Running e85 on stock fuel system
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Anthony Smith View Post
    Excellent info and detail. Thanks!! Where exactly is the injector table?? Maybe I just have to jump back into the tune this evening and take a look. I also understand what you're saying about the wideband and AFRs, Lambda = 1, etc. That makes sense.. Does the computer always target lambda = 1, and then target a percentage of lambda based on what the PE table/mode is targeting? (when you are on the throttle enough to enter PE mode).
    2002 GTP sedan:
  16. #16 Re: Running e85 on stock fuel system
    Mar 2014
    Cincinnati, OH
    In addition, the computer targeting lambda = 1 would help validate why DarkHorizon was able to get away with just switching to E85 and 42.5 lb injectors and not changing the tune at all and still running okay... right?
    2002 GTP sedan:
  17. #17 Re: Running e85 on stock fuel system
    Arizona
    By running okay is a very relative word.. What I dean OK might be ****ty to you.
    Trust that you'll want the injector data input into the PCM. You'll want proper driveability transients etc...
  18. #18 Re: Running e85 on stock fuel system
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by 91parkave View Post
    Yepp, I would swap the injector data and compensate for 30% addition needed for E85 at a minimum probably. Guess from there I would just do a lot of scanning and monitoring to find out what I'd need to change/tune along the way.
    2002 GTP sedan:
  19. #19 Re: Running e85 on stock fuel system
    Feb 2009
    flintnasty MI
    You dont need to change the "injector data" for e85 and 42s... when you have e85 in the tank your injectors automatically get smaller... it just so happens that 42s turn into 33s... guess what you already have a pcm tuned for 33s.
  20. #20 Re: Running e85 on stock fuel system
    Feb 2009
    flintnasty MI
    For reference on "it will probably run bad"
    The race cars with turbos... run 18:1 afr at cruise with lower than gas egt.. on stock timing.
    I have tested wot afr from 10.5 to 13.5 with very little power difference inbetween. Not to say there are situations where you would want rich or lean setups but for the "I wanna run e85 and a smaller pulley" guy its going to work fine.
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. fuel rail question...stock for stock..
    By StandAloneCustoms in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2013, 08:11 AM
  3. Am i running out of fuel?
    By GTP4 in forum PCM Tuning
    Last Post: 12-31-2008, 05:11 PM
