Thread: Running e85 on stock fuel system
Results 1 to 20 of 37
  1. #1 Re: Running e85 on stock fuel system
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Isn't the tune as simple as adjusting the stoich. reference in the cruise tables, and then changing the PE target AFRs as well for the E85?? Wondering if I could pick up injectors, a stock pump rewire, and tweak as few as 2 or 3 tables in my tune and run full E85 without any issues.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Running e85 on stock fuel system
    Apr 2011
    Vassar, Mi
    Quote Originally Posted by 97AutoXVette View Post
    You completely can. I picked up a set of 60's used cheap, bolted them in. No need to change any target AFR's, Stoich for all fuels = Lambda 1 it doesnt matter if its E85 or gasoline the O2 sensor doesnt know the difference. For instance running E85 with a wideband setup for gasoline, when it is showing 14.7 you are actually at E85 stoich of 9.76 or lambda 1 all the way around. The gauge is just converting lambda 1 from the sensor to AFR so you have something relatable to read on the gauge. Your stock narrowband works the same way. AFR is just a way to read stoich for different fuels.
    Either way all I needed to do is change the injector tables from stock to 60's then the 30% for e85. Ran the tank dry with the pump on and a fuel line off then filled with E85. Fired right up with no other changes, no pump, no rewire, no injector o-rings, not even a filter change, only took 20 minutes. After that I set the timing from stock to 22* and dropped from my 3.4" pulley to my 3.1" picked up probably 30 hp.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  3. #3 Re: Running e85 on stock fuel system
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Anthony Smith View Post
    Excellent info and detail. Thanks!! Where exactly is the injector table?? Maybe I just have to jump back into the tune this evening and take a look. I also understand what you're saying about the wideband and AFRs, Lambda = 1, etc. That makes sense.. Does the computer always target lambda = 1, and then target a percentage of lambda based on what the PE table/mode is targeting? (when you are on the throttle enough to enter PE mode).
    2002 GTP sedan:
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. fuel rail question...stock for stock..
    By StandAloneCustoms in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2013, 08:11 AM
  3. Am i running out of fuel?
    By GTP4 in forum PCM Tuning
    Last Post: 12-31-2008, 05:11 PM
