Thread: Running e85 on stock fuel system
Results 1 to 20 of 37
  1. #1 Re: Running e85 on stock fuel system
    Feb 2009
    flintnasty MI
    You can swap 42lb injectors in with the e85 swap and it runs great no tuning.
    I imagine you will struggle with fuel pumps and filters making sure that you dont drop fuel pressure.
    With 33lb stock injectors you can run about e60 on a stock pulley. You will see a very small mileage drop. Its a great money saver and you can mix with 87 octane.
    http://www.grandprixforums.net/threa...e-in-E85-areas
  2. #2 Re: Running e85 on stock fuel system
    Arizona
    All injectors are not the same you don't just plop in bigger injectors without proper data, what about your transients?
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. fuel rail question...stock for stock..
    By StandAloneCustoms in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2013, 08:11 AM
  3. Am i running out of fuel?
    By GTP4 in forum PCM Tuning
    Last Post: 12-31-2008, 05:11 PM
