Thread: New MAF Sensor - Problem
Results 1 to 5 of 5
  1. #1 New MAF Sensor - Problem
    Jun 2013
    boston
    So my car (1999 Grand Prix GTP) bogs a little when I just start accelerating. I cleaned the MAF sensor, and it did not make a difference. I ordered a new one and put it in and it is actually worse now. It is the same bog as before, but now when I am on highway or cruising >30mph at 1500 RPMs - the RPMs jump up and down and the car rocks.
    This actually happened to my old 2001 Grand Prix GTP when I first bought it. I kept bringing it back to the dealership and they couldn't figure out what the problem was. Then one day they fixed it, but I am not sure what they did.
    Should I just throw my old MAF sensor in, or is their a way to fix this? Kind of odd that a new MAF runs worse than the old one.
    Thanks. Happy New Years!
  2. #2 Re: New MAF Sensor - Problem
    Nov 2010
    Ray MI
    What kind of maf did you get?
    Aftermarket ones can have problems. Do you have a scanner?
    I just had a lot of maf problems.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  3. #3 Re: New MAF Sensor - Problem
    Jul 2012
    Chicago
    Clogged cat?
    Bad coil/ICM?
    -Carl
  4. #4 Re: New MAF Sensor - Problem
    Jun 2013
    boston
    It is a "Standard" MAF. The sputtering did not occur with the previous MAF, so I am wondering if the computer needs a reset or something. I have an Aeroforce scanner - there are no codes coming up. I also used a Snap-On scanner and there was nothing irregular MAF related sequences (says my mechanic).
  5. #5 Re: New MAF Sensor - Problem
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    If it got worse with a new maf I would guess clogged cat. It would be nice to know that the readings from the old maf vs the new maf where
    I went NA when a whore left -$300 in my bank account.
  1. MAF sensor problem?
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 06-03-2013, 08:26 PM
  2. MAF sensor problem
    By GTP Chic in forum General Tech Discussion
    Last Post: 05-07-2013, 02:41 AM
  3. Do I have an O2 sensor problem?
    By ronmexico in forum General Tech Discussion
    Last Post: 04-13-2012, 09:41 AM
  4. Temp sensor problem
    By keadams in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2012, 01:29 PM
  5. knock sensor problem??
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 02:26 PM
