Thread: need some help pls
Results 1 to 6 of 6
libster need some help pls 12-05-2008, 05:18 PM
Blown97 Re: need some help pls 12-05-2008, 09:42 PM
t24moore Re: need some help pls 12-05-2008, 10:09 PM
gtpinsc Re: need some help pls 12-05-2008, 10:34 PM
libster Re: need some help pls 12-06-2008, 07:04 AM
Guest Re: need some help pls 12-06-2008, 10:32 AM
  1. #1 need some help pls
    Apr 2008
    upton ma
    well i got my quick change fp from the w body store and started to install.. first off the top plastic part "i would call the hat " was lager than the stock one so the retainer would not fit over it.... no big deal just a little dremel work all set..
    how do u get the retainer ring back on ive tryed everthing i can think of
    2003 gtp sedan blk on blk -motorsports cai- 3.5 zzp mod . aero force gauge-intense standard pcm w raise shift points and more timing- 180 stat. ss plog -2.5" dp-autolite 104s
  2. #2 Re: need some help pls
    Feb 2008
    Are you talking about the retainer ring that you have to take off to get the whole unit out?
    If so, it goes in pretty much the reverse of how you took it out. If you are having problems, you could possibly have something under the FP unit that it keeping it from seating all the way and causing it to stick up where there is not enough room for the ring.
    It's hard to tell without looking at it. Let us know!!
  3. #3 Re: need some help pls
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    A bunch of cursing and raising your hands. I caught hell trying to get the ring in my stock one. A snap ring tool helps a bunch too.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  4. #4 Re: need some help pls
    Jul 2008
    sumter,south carolina
    ive been there done that,pretty much what they are saying.u just gotta play with it.if u dont have a snap ring tool.A pair of needle nose pliers helps also.It comes out alot easier than it goes back in.
    02 GTP with mods 05 GP for DD
  5. #5 Re: need some help pls
    Apr 2008
    upton ma
    there is no snap ring its a metal ring with 4 slots in it that goes over 4 ears on the tank then rotates clock wise to lock as u r pushing it down to seat..
  6. #6 Re: need some help pls
    TDCRacing
    Guest
    Ok so you should be able to put it in the reverse as you took it out. Possible the pump isint seated all the way? like someone else mentioned.
pls
